Eye of the Toiger
Weber re-build
Hi
I Have an old set of webers from that I want rebuilt for a 3.0 Can some one tell me the following I need to suit a 3.0 SC motor 1. Venturi size - I'm guessing 34-36mm 2. idle jet size 3. air correction jet size 4. Emulsion tube size Who would sell set shafts and floats for the weber carbs? What else do I need?? Cheers matt
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
Check out Links 1 for info on jet sizes and this place has the parts...
http://youroil.net/weber_carb_parts.html Our host likely has parts too. |
The answers to your questions really depend on the engine's configuration: cams, compression ratio. exhaust system, usage, as well as environmentals.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Eye of the Toiger
At the moment stock 78 3.0 SC with ssi's and 2in 2 out exhaust, street and track.
Later I will put in some JEs and GE60 cams. Steve - does your company rebuild webers? I need some one to rebuild them. cheers Matt
