kodioneill's Avatar
old style ring compressor
doe's anyone know where i can purchase the old style ring compressor? it's a 3 piece set with two parts ( like crescents ) that fit into a round hollow handle.
it was also used on air cooled Volkswagen engines.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 10-01-2008, 02:04 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
I recommend the ARP ring compressor. They are sized for only one piston size, but they work perfectly. and it's American-made.
http://store.summitracing.com/partdetail.asp?part=arp-901-9000
I have the 80, 84, 90, 95 and 98mm versions and so far that's done every motor I've built.
Scott Kinder
kindersport @ gmail.com
Old 10-01-2008, 02:24 PM
kodioneill's Avatar
do you like the method of installing the pistons in the cylinders first then installing the wrist pin?
i prefer installing the cylinder over the piston with the piston connected to the rod.
1982 chiffon 911sc
Old 10-01-2008, 02:49 PM
YTNUKLR's Avatar
Yes I like to install the pistons into the cylinders as a unit then slide the assembly onto the head studs where you then align the rod and knock the wristpin home. I think the other method (piston on rod, slide cylinder on) does not give a good sense or "feel" of how much force you are exerting on the rings if it is not perfectly aligned. I know that's how the Porsche factory did it but I feel the 1st method is superior
Scott Kinder
Old 10-01-2008, 02:56 PM
kodioneill's Avatar
thanks for your input
1982 chiffon 911sc
Old 10-01-2008, 03:08 PM
silver911rdb's Avatar
I know this is an old post but I'm looking for the ARP 98mm ring compressor YTNUKLR recommends above. I can't seem to find it and it's not listed in the APR website. What are you guys using for 98mm ring compressors? I'm having a heck of a time installing my pro seal rings with my old school ring compressor. It's just not going to happen with my compressor.
Any ideas? thanks
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 07-23-2016, 01:44 PM
YTNUKLR's Avatar
Wiseco just as good.
https://www.hptautosport.com/products/wiseco-tapered-piston-ring-compressor-98mm-bore-rcs09800
Old 07-23-2016, 02:53 PM
ring compressor tool
I have Hazet ring compressor tool which is adjustable from 75mm-104mm I have used for 40 years.Pricey when I bought it but one tool does them all.Fred
Old 07-23-2016, 03:22 PM
YTNUKLR...thanks! That's exactly what I was looking for.
-Rich-
1984 911 Track
Old 07-23-2016, 04:48 PM
