Cam Sprocket Shims
Anyone have a spare shim or two they'd be willing to mail to me in an envelope? I just checked sprocket alignment and I'm .51mm shy on the right side. I'd hate to have to place an order just for two shims....
![]() Mike...
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold |
Mike
I've got plenty. PM me with your mailing address if you still need them.
Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process |
Much appreciated Tom, PM sent.
Tom,
Rechecked measurements this morning and came to realization that I need to remove, not add shims... . Thx for your offer to help though. As others have already said on other threads, you're a great guy.... ![]() Mike...
Irrationally exuberant
If you have 3 on the left and 4 on the right, you're motor is sprocket alignment is probably good. What was your measurement technique?
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Chris,
I actually started with 5 on the left side and 4 on the right based on what was in there previously. Followed the procedure in Wayne's book and determined that I had to remove one on the right side. Rechecked measurements several times to confirm. Installed new intermediate shaft sprockets and sent the cams out to be reground, so I couldn't assume the original shim stacks were correct. Also, noticed signs of misalignment wear on the back side of the right hand sprocket, further confirming the measurements. Mike...
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold Last edited by SCrescue; 10-05-2008 at 07:02 AM.. |
Little known fact (at least I didn't used to know), the shims are the same as the ones on your alternator pully.
-Andy
72 Carrera RS replica, Spec 911 racer |
I did a little digging and they are the same part number for a '73 but somewhere along the line the fan shim got a different part number. I checked '83 and an '87 901 105 561 00 for the cam shim 930 106 564 00 for the fan shim I wonder if the fan shim changed dimensions at some point? -Chris
HI Chris
the shim has changed on the outside, it is smaller to fit in the double pulley on the SC fan. regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
Since we are talking cam shims...
During my recent rebuild on a stock '75 (911/44) I found that my shims were 0.5 mm thick. Wayne's book described them as being 0.25 mm thick. Is this a unique abberancy? I also noted that the thrust washers were of slightly different thickness - (3.9 vs 4.0 mm or something like that) presumably to allow finer cam alighnment adjustment?
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon |
