River Rat
Dave 86 930 Fl's Avatar
Cam Timing - Remove rocker arms?
I'm in the process of reassembling my motor after replacing all of the head studs, two were broken. My question is regarding the cam timing and whether I need to remove the rocker arms (2,3,5,6) in order to properly time the cams. I removed the heads and cam towers in one piece and I have not disassembled them. So, I'd prefer to set the timing with the heads fully assembled.
Any reason why I can not proceed with all of the rockers in place?
Regards, Dave
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 10-14-2008, 04:36 AM
Dave,
You don't have to remove them, but you should back the adjusting screws all the way out (all 12) before installing the chains and rotating the crank to TDC on #1.
Mike...
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold
Old 10-14-2008, 06:23 AM
River Rat
Thanks Mike.
Old 10-15-2008, 03:21 PM
