jmancool's Avatar
Rebuild website
Hi All, does anyone know or can recommend a good 911 engine rebuild website that has set-by-set information? Regards J
Old 08-01-2009, 04:11 PM
There is a bunch of Aussis on here and there should be at least a couple with several builds under their belts
Just get the spec book and a few tools and remember how you took it apart..I didnt have digital cameras and computers when I started. Torque by the spec book or by the instructions.
Sub assemble everything, the crank and rods, the pump and inter shaft and chains, the heads comeback from the shop assembled, seal them to the cam carrier, install the cams, rockers and even set the valves in 2 groups of three. Notice how the rockers line up with the narrow side on the cam carrier.
Everything you do is learning. There is loads of doubt, good deal of sealants, but if you lay everything out clean, you will use it all
Bruce
Old 08-01-2009, 04:43 PM
304065's Avatar
Uhh, you are on the definitive resource for 911 engine rebuilding in the world.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-01-2009, 05:50 PM
jmancool's Avatar
Bruce
Thank you for your insightful information. I have a repair manual and know how the engine came apart. I can’t find the chapter called Lessons learned or After 200,000km’s what happens, Different head studs or Modified chain tensioner in my workshop manual…..You don't find experience in workshop manuals only how to pull apart a new clean engine. I'm after a knowledgeable person/people that have rebuilt these engines (in the 21st century) so I can learn from their many varying experiences. Cheers big ears.
Old 08-01-2009, 08:47 PM
I'm here to cause trouble
jimbauman's Avatar
Simple - you need "Wayne's Book..."
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 08-01-2009, 10:21 PM
Less brakes, more gas!
euro911sc's Avatar
JB
See Above. There is no substitute...
-michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 08-02-2009, 07:09 AM
jmancool's Avatar
Got "Wayne's" book for Christmas - fantastic book, well done Wayne.
1979 3.0 911 SC
Old 12-25-2009, 10:26 PM
DanielDudley's Avatar
There is a fantastic video of a 1/8 scale model engine being assembled on the Off Topic forum. While it isn't a ''real'' 911 engine, it may be the kind of video you would like to see, as it gives one a clear picture of how the parts fit together in 3D. Once you see it, it becomes clear that while a 911 engine is different from your basic inline four or V8, it is a logical and relatively simple unit, with no voodoo involved.
Old 12-26-2009, 04:35 AM
idc1873
coxy's Avatar
Impact bumpers
try
www.impactbumpers.com
Regards
Coxy
Old 12-26-2009, 06:15 AM
Certified Porscheaholic
777joee's Avatar
Between this site and Wayne's book you should be able to build any 911 motor you want.
One rule of thumb. KEEP IT CLEAN then CLEAN IT AGAIN!
Dave Mitchell
Proud owner of "The Beast"
2010 Intermeccanica Speedster with 100% 1980 Porsche 3.0L power and suspension.
http://photobucket.com/IM-6build http://www.intermeccanica.com/
Old 12-31-2009, 06:08 PM
Author of "101 Projects"
Wayne 962's Avatar
Thanks! I spent a lot of time on it. I just finished 98 projects on the new Boxster book!
-Wayne
Old 01-06-2010, 12:52 AM
Drive it like u stole it.
jonesb930's Avatar
-Wayne
So does that mean 3 more (to make it 101) and you can start the transmission book???
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 01-06-2010, 12:28 PM
