Rebuild website
Hi All, does anyone know or can recommend a good 911 engine rebuild website that has set-by-set information? Regards J
There is a bunch of Aussis on here and there should be at least a couple with several builds under their belts
Just get the spec book and a few tools and remember how you took it apart..I didnt have digital cameras and computers when I started. Torque by the spec book or by the instructions. Sub assemble everything, the crank and rods, the pump and inter shaft and chains, the heads comeback from the shop assembled, seal them to the cam carrier, install the cams, rockers and even set the valves in 2 groups of three. Notice how the rockers line up with the narrow side on the cam carrier. Everything you do is learning. There is loads of doubt, good deal of sealants, but if you lay everything out clean, you will use it all Bruce |
Uhh, you are on the definitive resource for 911 engine rebuilding in the world.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
I'm here to cause trouble
Simple - you need "Wayne's Book..."
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
Less brakes, more gas!
See Above. There is no substitute...
-michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Got "Wayne's" book for Christmas - fantastic book, well done Wayne.
1979 3.0 911 SC |
There is a fantastic video of a 1/8 scale model engine being assembled on the Off Topic forum. While it isn't a ''real'' 911 engine, it may be the kind of video you would like to see, as it gives one a clear picture of how the parts fit together in 3D. Once you see it, it becomes clear that while a 911 engine is different from your basic inline four or V8, it is a logical and relatively simple unit, with no voodoo involved.
idc1873
Impact bumpers
Certified Porscheaholic
One rule of thumb. KEEP IT CLEAN then CLEAN IT AGAIN!
Dave Mitchell Proud owner of "The Beast" 2010 Intermeccanica Speedster with 100% 1980 Porsche 3.0L power and suspension. http://photobucket.com/IM-6build http://www.intermeccanica.com/ |
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Drive it like u stole it.
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
