'73 911S Sepia Braun
Vintagemotion's Avatar
How to build 2.2 with 9:1 compression
Using the original crank and boring the original cylinders - what option do I have to get 9:1 compression?
Who makes such pistons?
What can be done to crankcase or cylinder to increase compression?
thanks
RJ
Rolf
'73 Porsche 911 S MFI (original till now)
'63 Mercedes 220SEB MFI
'73 BMW R75 AHRMA Race bike
vintagemotion@gmail.com
Old 01-21-2009, 08:08 PM
3 restos WIP = psycho
kenikh's Avatar
Use 2.2S pistons...you'll find that they cc out much closer to 9:1 than 9.8:1. JE will make pistons to any spec you want for reasonable money, too.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-21-2009, 08:24 PM
Solution:
JE pointed me to EBS racing. They have 85mm millimeter JE pistons that are custom made for 9:1 compression on the stock 2.2 crank. They said boring 84mm stock steel cylinders is no problem.
Rolf
Old 01-26-2009, 03:25 PM
kenikh's Avatar
Yep - that'll do dandy. I don't love the iron cylinders, but as long as you don't go racing it, heat soak shouldn't be an issue.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-26-2009, 03:28 PM
besides the weight - what's the issue with cast iron?
Rolf
Old 01-27-2009, 05:55 AM
kenikh's Avatar
They really suck at cooling, so only low HP applications apply. That's why Porsche only used them on 'T' cars - well that and they are cheap to build.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-27-2009, 05:59 AM
304065's Avatar
I'm confused, a 2,2E was originally 9,1 compression, why not just use E pistons?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-27-2009, 06:23 AM
OK , I did not know that only the T came with cast iron. Is this true for all years the T was made?
Rolf
Old 01-27-2009, 09:39 AM
Crankcase and/or heads milled.
Rod small ends offset bored (not strictly crankcase or pistons but cheaper than either)
Any of these will bump your compression a bit.
andy
Old 01-27-2009, 02:57 PM
yes
I believe the really early cars (64-66) ran iron cylinders
the 67-73ish went to biral cylinders in the S/E models
and then nickies and alusil on the 2.7's
but I believe all T's used the iron cylinders.
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 01-27-2009, 09:54 PM
"I believe the really early cars (64-66) ran iron cylinders"
Is this correct?
I though only the T motors had the cast iron cylinders and the the early motors used birals.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-28-2009, 02:25 AM
304065's Avatar
Originally Posted by Brant View Post
yes
Brant, actually all the early motors (production of course, I am excluding chromal and exotic prototype stuff) until the introduction of the 911T in 1968 used Biral cylinders. Nikasil came in with the 917 in 1971 and was used in the production cars from 1974. ('73RS was Nikasil)
Tom Butler is correct.
'81 R65
Old 01-28-2009, 06:18 AM
John, Tom,
you both know so much more than I
I completely defer...
I didn't realize the early cars used biral, but I am sure you are right
brant
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 01-28-2009, 07:54 AM
Thanks for all the good info!
Another question: What does the compression height of the piston need to be in order to get 9:1 with a 2.2 crank?
RJ
Rolf
Old 01-28-2009, 03:19 PM
Navin Johnson
TimT's Avatar
why so hung up on 9:1?
Get some off the shelf 9.8 or 9.5 pistons and be done with it? or maybe the 10.5 that JE makes...
Lots of options, and not so much mystery
'69 911 GT-5
'75 914 GT-3
and others
Old 01-28-2009, 05:35 PM
If you use 2.2 pistons with the longer stroke 2.4 liter crank the CR will increase about 0.55 pts due to the longer stroke.
So 2.2T pistons would produce 9.1 CR, 2.2E pistons would produce around 9.7 and 2.2S pistons would produce around 10.3 CR with the 70.4 mm stroke 2.4 crank.
Your best bet for street driving on pump gas would be either the 2.2T or 2.2E pistons.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 01-28-2009, 05:39 PM
Being a T you probably have a non-CW crank in there currently.
If you wanted to stroke it this would be a excuse to get a CW
crank.
andy
Old 01-28-2009, 06:27 PM
crank.
andy
What do you mean by CV?
Rolf
Old 01-28-2009, 06:49 PM
9:1 will give me the most efficiency / power without having to worry about gas quality.
Rolf
Old 01-28-2009, 06:52 PM
To look at this a bit more quantitative I still like to know what the compression heights of a 2.2E, 2.2T 2.4E 2.4T. Distance wrist pin to piston top?
Rolf
Old 01-28-2009, 06:58 PM
