Enlarging the displacement in 3.0SC engine ?
Hi there,
I am planning to stroke my 180hp 3.0sc engine and starting to collect information of the good combinations. the special interest is in Motormeisterīs 3.0 to 3.8 Big Bore Stroke Conversion Kit =>
6-New 3.8 Forged Billet Pistons
6-Biral Steel Lined 3.8 Cylinders
6-New Light Weight 3.8 Writ Pins
12-Spiral Racing 3.8 Piston Pin Locks
Hi -Compression
3.8 Stroker Crankshaft
Racing 3.8 H-Beam Connecting Rods
No More Cylinder Expansion
Increased Horse Power
Increased Longevity
Any experience of this scale displacement increase impact to rev limits etc ? how about the head...should I consider twing-plugging the current std head ? cam ?
I am using the Megasquirt EFI with the engine and the use case is street & track.
So all the hints are welcome regarding rear wheel power increase, torgue and driveability issues ? I donīt want built a turbo charged engine but I migt consider supercharger accompanied with 3.8 displacement if the engine block can tolerate charging.
so in short all the hint, dyno chart etc are welcome
Br
Sami (Finland)
Old 11-16-2008, 09:02 AM
How many HP would you expect to get from that set up?
Old 11-16-2008, 09:14 AM
Hi,
I am "dreaming" a bit over 300 rwhp with decent low end torgue as well to make driving in normal traffic ok as well.
Br
Sami
Old 11-16-2008, 09:22 AM
safe's Avatar
Do a search on Motormeister and try and find a thread that doesn't compose largely of the words "suck", "bastards", "thieves", "a$$ holes" etc...
Magnus
Old 11-16-2008, 09:39 AM
Free minder
Aurel's Avatar
First word of advise: I would stay away from anything having to do with Motormeister. They have a terrible and well deserved reputation going from bad customer service to fraudulent engine rebuilds. I would not even trust anything they sell. Anyways, I would use and abuse the search feature on this website, all the info is there. Here is a thread on the 3.6L motormeister kit to get you started...
MotorMeister 3.6 Big Bore Kit and Weber Kits
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 11-16-2008, 09:43 AM
Ok, got the point.. MM not the dream source (thanks regarding good hint anyway because I am not in US) . Letīs forget the source for a while and focus the basic questions to understand which kind of powerband etc I could expect if stroking to 3.6-3.8 (cam, heads porting, valves, airflow, EFI, etc....)
is +300 rwhp dreaming ?
hints and considerations ?
Br
Sami
Old 11-16-2008, 09:59 AM
safe's Avatar
You will have to ditch the intake and get an ITB-system so you can use a cam that support 300+ rwhp.
Magnus
Old 11-16-2008, 10:11 AM
Free minder
Aurel's Avatar
I think 3.7L is the maximum you can do with a 3.0L case, according to this thread:
Maximum bore on 3.0 911SC case?
In his book, Wayne describes such a 3.7L motor, and that will give you 280-300 hp.
Aurel
Old 11-16-2008, 10:49 AM
I think I was reading that article somewhere deep in www ...if I remember correctly it was still with original cis system when he was promisin 280-300 hp.
Br
Sami
Old 11-16-2008, 11:38 AM
safe's Avatar
280 fwhp from a 3.6 CIS, probably possible.
Best bang for the buck is a 3.6 transplant, shouldn't cost you more than ~2-3000€ if you have a healthy 3.0 to sell.
Magnus
Old 11-16-2008, 11:52 AM
Recreational User
porschenut's Avatar
With that size cylinder and high compression, you will definitely need dual ignition.
Old 11-16-2008, 04:56 PM
what is the rule of thumb when to consider dual plugging ? any direct hints reflecting the cylinder size vs compression ?
Br Sami
Old 11-18-2008, 09:45 AM
joetiii's Avatar
Br Sami
regardless of compression, I've read that 98 mm cylinders is about the limit on single plu due to the time it takes for the flame to travel from sparkplug to furthest cylinder wall.
joe
'69 911 E Targa - aka "RoxiE"
Old 11-18-2008, 04:21 PM
3 restos WIP = psycho
kenikh's Avatar
Keep the 70.4mm crank and talk to Charles Navarro at LN Engineering about the biggest pistons and cylinders he can help you fit to a 3 liter case. You will be pleasantly surprised.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-18-2008, 07:26 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Getting a 3.6 is cheapest when you start with a 3.6.
Scott Kinder
kindersport @ gmail.com
Old 11-19-2008, 04:16 AM
safe's Avatar
Br Sami
If you stay at 95 mm bore 10.5:1 should be OK with single plug, if you have the same gas in Finland as in Sweden (98 euro octane). Higher and or bigger bore definitely twin plug.
Thats the advice I got from Swedish engine builders, but on the other hand twin pluging is always a good idea, not to mension good looking.
Magnus
Old 11-19-2008, 04:25 AM
kenikh's Avatar
98 Euro octane is a bad combination for 10.5:1 IMHO. Maybe OK in a Finnish winter, but not in US weather. Single plug US max is 9.5:1 on 91 octane (RON+MON)/2 - assuming Finalnd is RON only. Twin plug anything 9.5:1 and over on US gas.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-19-2008, 12:07 PM
safe's Avatar
10.3:1 kompression on all euro 3.2 engines, so 10.5 isn't far off.
Magnus
Old 11-20-2008, 01:19 PM
kenikh's Avatar
Not on USA gas. Also realize that you are giving up timing for compression.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-20-2008, 01:25 PM
safe's Avatar
Yes, but neither Sami or myself are in the USA
Magnus
Old 11-20-2008, 01:33 PM
