Enlarging the displacement in 3.0SC engine ?
Hi there,
I am planning to stroke my 180hp 3.0sc engine and starting to collect information of the good combinations. the special interest is in Motormeisterīs 3.0 to 3.8 Big Bore Stroke Conversion Kit => 6-New 3.8 Forged Billet Pistons 6-Biral Steel Lined 3.8 Cylinders 6-New Light Weight 3.8 Writ Pins 12-Spiral Racing 3.8 Piston Pin Locks Hi -Compression 3.8 Stroker Crankshaft Racing 3.8 H-Beam Connecting Rods No More Cylinder Expansion Increased Horse Power Increased Longevity Any experience of this scale displacement increase impact to rev limits etc ? how about the head...should I consider twing-plugging the current std head ? cam ? I am using the Megasquirt EFI with the engine and the use case is street & track. So all the hints are welcome regarding rear wheel power increase, torgue and driveability issues ? I donīt want built a turbo charged engine but I migt consider supercharger accompanied with 3.8 displacement if the engine block can tolerate charging. so in short all the hint, dyno chart etc are welcome ![]() Br Sami (Finland) |
How many HP would you expect to get from that set up?
Hi,
I am "dreaming" a bit over 300 rwhp with decent low end torgue as well to make driving in normal traffic ok as well. Br Sami Last edited by Supi; 11-16-2008 at 09:39 AM.. |
Do a search on Motormeister and try and find a thread that doesn't compose largely of the words "suck", "bastards", "thieves", "a$$ holes" etc...
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Free minder
First word of advise: I would stay away from anything having to do with Motormeister. They have a terrible and well deserved reputation going from bad customer service to fraudulent engine rebuilds. I would not even trust anything they sell. Anyways, I would use and abuse the search feature on this website, all the info is there. Here is a thread on the 3.6L motormeister kit to get you started...
MotorMeister 3.6 Big Bore Kit and Weber Kits Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wifes) 2010 Honda Civic LX (daughters) |
Ok, got the point.. MM not the dream source (thanks regarding good hint anyway because I am not in US) . Letīs forget the source for a while and focus the basic questions to understand which kind of powerband etc I could expect if stroking to 3.6-3.8 (cam, heads porting, valves, airflow, EFI, etc....)
is +300 rwhp dreaming ? hints and considerations ? Br Sami |
You will have to ditch the intake and get an ITB-system so you can use a cam that support 300+ rwhp.
Free minder
I think 3.7L is the maximum you can do with a 3.0L case, according to this thread:
Maximum bore on 3.0 911SC case? In his book, Wayne describes such a 3.7L motor, and that will give you 280-300 hp. Aurel
I think I was reading that article somewhere deep in www ...if I remember correctly it was still with original cis system when he was promisin 280-300 hp.
Br Sami |
280 fwhp from a 3.6 CIS, probably possible.
Best bang for the buck is a 3.6 transplant, shouldn't cost you more than ~2-3000€ if you have a healthy 3.0 to sell.
Recreational User
With that size cylinder and high compression, you will definitely need dual ignition.
what is the rule of thumb when to consider dual plugging ? any direct hints reflecting the cylinder size vs compression ?
Br Sami |
regardless of compression, I've read that 98 mm cylinders is about the limit on single plu due to the time it takes for the flame to travel from sparkplug to furthest cylinder wall.
joe ------------------ '69 911 E Targa - aka "RoxiE" |
3 restos WIP = psycho
Keep the 70.4mm crank and talk to Charles Navarro at LN Engineering about the biggest pistons and cylinders he can help you fit to a 3 liter case. You will be pleasantly surprised.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
up-fixing der car(ma)
Getting a 3.6 is cheapest when you start with a 3.6.
Scott Kinder kindersport @ gmail.com |
Thats the advice I got from Swedish engine builders, but on the other hand twin pluging is always a good idea, not to mension good looking.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. Last edited by safe; 11-19-2008 at 04:29 AM.. |
98 Euro octane is a bad combination for 10.5:1 IMHO. Maybe OK in a Finnish winter, but not in US weather. Single plug US max is 9.5:1 on 91 octane (RON+MON)/2 - assuming Finalnd is RON only. Twin plug anything 9.5:1 and over on US gas.
10.3:1 kompression on all euro 3.2 engines, so 10.5 isn't far off.
Not on USA gas. Also realize that you are giving up timing for compression.
