idc1873
coxy's Avatar
Question Valve stem seals
Ready to install new valve stem seal, is there a specific way to installing them as mine are are very tight fitting and will not go home fully. Any tips/tricks to fitting them.
Old 01-12-2009, 01:46 AM
MBEngineering's Avatar
HI coxy
the seals are tight to fit, I made up a tool to fit them and to fit them on the guide square, you will need to check the top of the guide has no sharp edge, as it will pull the inside of the seal on fitment .
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 01-12-2009, 03:05 AM
little plastic cover?
Did you get the little plastic hat to put on the valve stem to slide the seal over?
I spread a very thin coat of grease on the inside of the seals to help them onto the guides, I've always done that on valve stem seals.
Old 01-12-2009, 03:10 AM
idc1873
coxy's Avatar
No didnt get a little plastic hat, what sort of tool is required? i tried a socket, couldnt get them to go home fully. Are they a push fit or could they do with a tap.
Old 01-12-2009, 03:40 AM
abit off center
cgarr's Avatar
You really should make sure the seals are square on the guide, here is a tool I made to install the seals, works very well:
______________________
Craig
G2Performance
Old 01-12-2009, 07:56 AM
idc1873
coxy's Avatar
[QUOTE=cgarr;4412585]You really should make sure the seals are square on the guide, here is a tool I made to install the seals, works very well:
Thanks all, just the info i required.
Old 01-12-2009, 08:23 AM
idc1873
coxy's Avatar
Thanks agian guys, made myself a tool, touch of grease worked a treat.
Old 01-14-2009, 01:19 AM
Coxy, I think you just won the prize for most creative use of a dynabolt...well done - cheap solution to the problem
John
Old 01-14-2009, 03:19 PM
