Send a message via Skype™ to aircooledkiwi
Flywheel thickness
I'm replacing clutch/flywheel in my SC motor and have had flywheel machined and surfaced - looks good.
Minimum thickness for this flywheel is stated as 8.5mm, and after machining mine is 8.76mm. Should I use it?
For reference, a new flywheel measures 10.92 mm thick.
'02 S6 Avant
'93 C4
'77 911S Project
Old 12-15-2008, 08:48 AM
Manassas, VA
lucittm's Avatar
Enjoy the lightness! You are within spec and the metal doesn't really wear down that much.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 12-15-2008, 01:24 PM
OK - I hadn't considered the weight reduction but its probably significant with a ~20% decrease in thickness. I'm going to weigh them to check.
I just want reassurance that it will have a reasonable service life under normal street conditions with a fairly stock 3.0.
'02 S6 Avant
'93 C4
'77 911S Project
Old 12-15-2008, 01:48 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Less material means there will be a greater chance for surface cracking. If you intend to drive this engine hard, replace the flywheel. If your intent is casual drive, run the flywheel.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-15-2008, 07:40 PM
Thanks Henry - I'm going to run it.
BTW I just got my distributor back from you and it looks bloody beautiful! I didn't expect all the replating work and the really nice job filling in the old vacuum actuator hole etc. Excellent work.
'02 S6 Avant
'93 C4
'77 911S Project
Old 12-16-2008, 12:58 PM
