930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Question exploded view of 930 wastegate?
anyone have one of these for a 80 930 ? parts fische link or anything? I just want to be sure i put mine back together right
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-10-2008, 04:34 PM
beepbeep's Avatar
Search and you will find:
Thank you for your time,
Old 12-16-2008, 02:33 PM
juicersr's Avatar
Goran, great shot. Is there a way to tell what bar spring you have? Did the factory every put anything other than .8 bar spring, and did weltmeister, and other mnftrs use a way to identify springs like TIAL does? I got a used factory wastegate last year for a project, and it came with an extra spring, which the guy i bought it from wasnt sure if it was .8 or 1 bar. thanks
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 12-16-2008, 04:39 PM
h20cooled7's Avatar
very cool thank you!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-16-2008, 06:01 PM
beepbeep's Avatar
Main problem is that boost is not proportional to spring tension only. A spring will deliver different boost depending on sizing of turbo, exhaust backpressure, muffler design etc.
So what was 0.7 bar spring can become 0.9 bar spring of Zork tube is fitted.
Old 12-17-2008, 12:42 AM
juicersr's Avatar
Ahhh. Is this part of the effect known as 'Boost Creep?'
dzugautomobili.com
Old 12-17-2008, 04:04 AM
beepbeep's Avatar
No, it's just that exhaust gases will find it easier to escape trough wastegate if backpressure trough turbo is higher. They take path of least resistance.
Boost creep is when wastegate is too small to scavenge gases even when fully opened...so boost starts to raise at higher revs. This is usually not an issue with 930 wastegate as its valve is big enough.
Old 12-19-2008, 01:08 AM
Manassas, VA
lucittm's Avatar
Juice,
I take full credit for those pictures that Goran unashamedly posted. The second one was the pinched diaphragm from the PO's mechanic. That necessitated the rebuild shown in the first picture.
One more thing, the gasket between the cast iron valve body and the aluminum valve guide section is no longer available and when it tears upon disassembly, you will be OOL.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 12-22-2008, 11:49 AM
beepbeep's Avatar
I'm sorry for not giving correct credits, I just searched for "wastegate picture" and pasted the picture URL.
Old 12-22-2008, 05:19 PM
Toofah King Bad
Rasta Monsta's Avatar
Old thread I know. . .this still the case? Alternatives (other than junking the WG)?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-05-2010, 05:06 PM
johnman001's Avatar
I bought ultra-high temperature, very thick gasket material from McMaster Carr and made my own gasket for the NLA one. It worked fine.
I do, however, like the TiAL WG that is a direct replacement.
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 10-05-2010, 08:49 PM
brettm69's Avatar
Juice,
Mark
Why not use some generic 'sheet' gasket & a sharp X-ACTO
Also, I believe it's SOL, not OOL
Brett
Old 10-06-2010, 12:43 PM
Toofah King Bad
It's not paper, it's about 1/8" thick asbestos, and needs to be airtight or you'll have an intake leak.
Old 10-06-2010, 12:54 PM
johnman001's Avatar
Who said anything about paper?
Extra high-temperature gasket material (yes even 1/8" thick) is available in sheet form. It may be expensive, but it is available. It works well.
John Flesburg
Old 10-07-2010, 06:02 PM
Toofah King Bad
Well, I just started exploring McMaster's website a couple of nights ago, and I clearly have some learning to do about materials.
FWIW, Andial have a few of these left, so I bought one. . .figure it will be good for another 40 years.
Old 10-07-2010, 06:43 PM
