jluetjen's Avatar
Shroud Hardware is Stripping!
While I was putting shroud and baffling together on my race engine project, I found that the bolts that hold the left cover piece on kept stripping out as I tried to screw them into the bolts that clip onto the shroud.
Anyone else run into this? Am I using the correct bolt? It seemed to work on the other side...
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 12-31-2008, 08:56 AM
BURN-BROS's Avatar
John,
can you get a better pic of the threads? The bolt should have a very course sheet metal type thread, not the common metric thread you would use to mount the shroud cam towers, case, and fan ring.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 12-31-2008, 10:14 AM
I would rather be driving
jpnovak's Avatar
Aaron is correct. There are 3(?) of these coarse screws that mount in speed nuts clipped to the edge of the fiberglass. One DS two PS. They look very similar to front fender mounting screws (not the vertical fender support screws).
If you have the correct screw then bump the speed nut with a hammer to flatten (close) the two tabs that the screw mounts too. This should solve the problem. the other option is a new speed nut.
Old 12-31-2008, 10:35 AM
jluetjen's Avatar
Thanks. I'll start poking around in the the bag of bolts that I got in Pelican's rebuild kit and find the right screws.
John
'69 911E
Old 01-01-2009, 05:24 AM
