Strange piston damage
I am rebuilding a 3.2 Carrera and also do the 3.4 upgrade using the original Mahle 3.4l piston and cylinder set. I had the top engine assembled but ran into problems with one side where the cam would not turn easily.
So I decided to take this side apart again and reassemble it completely. When I looked at the pistons I noticed two dents on the side of the piston crown. It appears to various degrees on all 3 pistons in the same position. Please see below and notice the dents at the outer perimeter of the piston crown. One at about 150 degrees and the next in symmetric position at about 210 degrees:
I have no idea what is causing this. Anyone who can offer a suggestion what I need to look for?
1984 Neunelfer Carrera
Old 01-01-2009, 01:36 PM
Wer bremst verliert
JohnJL's Avatar
did you measure your "squish" clearance between the piston and the head?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 01-01-2009, 01:50 PM
I measured the deck height using the solder method. I am following the instructions in the Wayne Dempsey How to rebuild book.
Old 01-01-2009, 01:57 PM
syncroid's Avatar
I had a similar problem when I did my 3.4 liter conversion. My pistons didn't get dented but they were very slightly touching the heads. I had the heads chamferred (sp) and that took care of the problem.
Here are a couple pics of what mine looked like.
It looked like someone took a pencil and very lightly drew a line all the way around the edge of the piston.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 01-01-2009, 02:13 PM
I was thinking about this too. But what is really strange here is the two symmetrical dents and there is no area that would match the dents in the heads. If the pistons touches the head I would assume there is a broader range of marks, like in your case a line or a more elongated impression. Those two dents look really weird and are hard to explain I think. The interesting part here is the symmetry. This is puzzling. Your case makes much more sense to me. Those two dents don't match up with anything on the head.
Old 01-01-2009, 02:20 PM
syncroid's Avatar
Maybe Steve from RennSport or Henry Schmidt will chime in with a better answer. Good luck.
Dan
Old 01-01-2009, 02:22 PM
Since you did the same thing did you run into any issues with the cams are hard to turn after tightening the heads and cam housing? I assume you should be able to turn them relatively easily by hand.
I assume I can still use the pistons. I will just sand the rough edges a bit. However now I am worried about my other side. I hate to take it all apart again. Darned.
Old 01-01-2009, 02:26 PM
syncroid's Avatar
I had no issues with my camshafts not turning. I would highly recommend pulling the galley plugs in your cam towers and making sure they are clean and the oil squirt holes are clear.
Dumb question, but did you torque all the heads on first and "then" put the cam towers on? If so, try loosening all the head nuts and then retorqueing them again. You should be able to turn the cams by hand.
Your pistons should be okay so long as the ring lands are not crushed.
Dan
Old 01-01-2009, 05:14 PM
I followed the exact direction that is given in the book. The procedure if I recall correctly is to tighten the head nuts hand tight and then torque down the cam housing and finally torque the heads. I guess it is a matter of the tolerance in your parts. I will check the plugs. Thanks for the tip.
Old 01-01-2009, 05:22 PM
syncroid's Avatar
No prob. I always assemble the heads to the cam towers as a unit and then torque that entire assembly to the cylinders.
Dan
Old 01-01-2009, 05:27 PM
abit off center
cgarr's Avatar
Were the sealing surfaces of your heads machined at all? The cam not turning free is of concern.
______________________
Craig
G2Performance
Old 01-01-2009, 06:54 PM
Yes. The heads did undergo the machine shop and a complete overhaul.
Old 01-01-2009, 07:06 PM
How easy should the cams turn? I assume that they have a quite tight fit and will turn with a little of force meaning you can turn them by hand with some minor force. Is that an accurate assessment? I reassembled the other top end twice and on the second time around I can turn the cam with my hand with a little force applied. However when I move it slightly out it gets stuck. So it does not slide in and out easily which bothers me but maybe it is just a matter of tolerance and tight fit. I assume it cannot sit too loosely and also I have applied any lubrication. Thank you for thoughts and feedback on this subject.
Old 01-04-2009, 09:56 AM
E Sully's Avatar
The photo shows what an exhaust valve hitting the piston looks like. Nothing like your dents. Perhaps from how you installed piston in cylinder? My cam was binding initially on the right side after installation. The paper gasket between the chain housing and cam towers had folded slightly and this was enough to bind the cam. New gasket installed carefully and it turned well, just some light resistance from the assembly lube.
Old 01-04-2009, 11:15 AM
UNDER CONSTRUCTION!
carrera turbo's Avatar
did these get nicked or dented on the head studs on assembly and your chasing a ghost?
look at your second or third pic at there relation to the head studs?
just a thought.
thanks ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 01-04-2009, 11:57 AM
Thank you. I thought that too and I think this is what happened. I am surprised the surface is so soft because all I can think of is that I pulled them against the studs when removing the clips. The dents are exactly on the side where I removed/installed the circliips. So I am pretty sure that is it. Amazing how easy it is to damage something. So next time I will put a a rag around the piston when I work on the circlips. Apparently I am still learning. I never thought the stuff is so soft.
Old 01-04-2009, 02:37 PM
UNDER CONSTRUCTION!
little pieces of hose in the studs works wonders.
good luck
cheers ed
Old 01-04-2009, 03:04 PM
