911 piston casting numbers
I need the list of numbers of the casting on the inside of the piston that tells me exactly what the piston is.
There is also numbers on the outside of the cylinders cast in that should have a description as to what the numbers and++ signs mean
Any help is appreciated.
TIA,
Bruce
Old 11-06-2008, 12:58 PM
Tom1324racing posted a list some time ago, use search to find it.
andy
Old 11-06-2008, 03:04 PM
Here's the current version of my listing.
I have pics of most of these if you need help in identifying your pistons.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 11-07-2008, 03:37 AM
pistons
Thats the list I was looking for. I have a couple that are not on the list to add to it.
Thanks for the help
Bruce
Old 11-07-2008, 03:42 AM
Please let me know the ones you'd like to add and I'll put them in.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 11-07-2008, 06:01 AM
I need help, a have a 911 sc 1981 german engine, that i'm rebuilding .would like to know which piston to use regar to hp original piston are 95L70++ and 2nd. set are 95P36++ , i'm using the same 911 sc cylinders.
thanks
Old 12-03-2008, 08:06 AM
The 95P36++ are Carrera 3.2 pistons. They will not work with your stock SC crank and rods. You would have to have the wrist pin ends on the rods modified to work with the 3.2 pistons.
The 95L70 are the correct 3.0 SC Euro pistons for your motor.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 12-03-2008, 02:25 PM
Cornpanzer's Avatar
Anyone know what a 95P30 W2 is? I have some 95P30 RSR pistons and then I have the W2 version that has a huge dome on them.
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 12-29-2008, 06:31 PM
The 95P30 W2 shown in your pic is the 10.5 CR.
The standard 95P30 is the non CIS 9.8 CR
9.8 CR
10.5 CR
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 12-29-2008, 07:12 PM
Cornpanzer's Avatar
Tom, thanks for the pics and info! Excellent!
I guess we should correct the spreadsheet
Now, the big question...does anyone have a single they can part with so that I can make a set?
1970 911S,
RGruppe#252
Old 12-30-2008, 05:32 AM
Here's an updated/corrected version.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 12-31-2008, 11:01 AM
Tom
Could I ask if you have a similar ref list for cylinders.
I have
90ZN2 W1
90ZN2 W2
854/1B
854/2B
and would like to find out what they are
Regards
Mike
RS #1551 (Sold)
67S
Old 01-02-2009, 03:38 PM
854/1B
854/2B
These are both 90mm (2.7 liter) KS Alusil cylinders.
90ZN2 W1
90ZN2 W2
These are most likely 90mm (2.7 liter) Mahle Alusils.
Check to see if the inner bore is slightly magnetic. If the wall do not attract a magnet (like the KS cylinders), they are Alusil.
If they attract a magnet, they are Nikasil.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 01-02-2009, 04:44 PM
Thanks Tom
Regards
Mike
RS #1551 (Sold)
67S
Old 01-02-2009, 04:51 PM
