relayswitcher's Avatar
Send a message via Skype™ to relayswitcher
Red face Measure 11 blade diameter
Can you tell me where you measure the diameter on the fan. I know they vary form 3.75" to 3.25" and so on. But where exactly do you measure. Can someone photo shop a pic with lines showing where you get the exact measurement. Thanks, Relayswitcher.... full of questions today.
Old 01-03-2009, 07:17 PM
304065's Avatar
They are in mm not inches
245 mm from blade tip to blade tip across the center of the hole in the middle.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-04-2009, 09:19 AM
UNDER CONSTRUCTION!
carrera turbo's Avatar
i think maybe he means the pully size?
ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 01-04-2009, 03:40 PM
Try not, Do or Do not
Henry Schmidt's Avatar
There are only two pulley sizes made by the factory for eleven bladed fans.
Large (early) 8 hole pulley and small (later) 12 hole pulley.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-04-2009, 05:39 PM
UNDER CONSTRUCTION!
so is his question legit is there a 3.25 and a 3.75 pulley ?
i thought i have heard this as well.
thanks ed
Old 01-05-2009, 10:49 PM
I know it's been since January, but the measurements go as follows. And I found this in a Pelican tech article regarding changing out your fan to 11 blade....etc.
This measurement is taken from the metal "bumped up area" diameter at the center out to where it starts to flatten out for the big rivets .
911 & Year Fan Pulley Diameter
911 1965-74 3.75"
911 1975-77 3.25"
911SC 1978-79 3.125" (I think this is a mistake and should read 3.25.....not sure though.
911SC & Carrera 1980-89 3.25"
Old 09-23-2009, 04:51 PM
