Dynamohum, you are doing a fantastic job!
Where did you get that material for ceramic coating? Is it expensive? And how thick is the coating by your estimate?
'87 3.2 Targa |
Thank you for your kind words, I purchased the Ceramic Coatings from Tech Line Coatings Inc. http://www.techlinecoatings.com/BulkEngine.htm After consulting with one of their Engineers that assured me that the CBC2 Powerkote is able to withstand a comp ratio of 13 to 1 with a boost pressure of 1 bar and 1500 deg/f I decided to go with it over their other Ceramic product CBX, because the CBC2 can be polished. Its not that expensive ($ 24.95) considering a small 3oz bottle, is suppose to do up to 24, 4" pistons The recommended application thickness is .001" thousands of an inch. It is a water based product, high in solids and easy to apply with a small air brush.
Thank You for your time, Paul. We do because we can. 87 911 3.2 (Turbo conversion, build in progress, Thermal Barrier Coatings, High Pressure Dry film coatings) Modified heads, boat-tailed case, ARP hardware, OBX Header, 930 clutch disk, G50 Trans 89 5.0 Mustang convertible (For Sale) |
NOS911
Good Job Paul! Are those stock US or Euro pistons?
My Pelican Page Last edited by mxessin2; 02-16-2009 at 05:31 PM.. |
Thank You,
Stock US 95mm Motronic pistons 9.5 to 1 CR
