What type of camshaft is this?
I have a pair of centerlube camshaft with 47mm journals and 1,5mm thread for the sprocket nut. The right cam is marked with 362 498 and a "S" between the exhaust lobe of cyl 4 and intake lobe of cyl 5. The left cam has the drive for MFI pump. Anyone who knows make and info about these cams?
Old 02-03-2009, 12:35 PM
Try not, Do or Do not
Henry Schmidt's Avatar
If the cam has 4 cam journals it is probably a set of 906 cams.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-03-2009, 05:27 PM
