What type of camshaft is this?
I have a pair of centerlube camshaft with 47mm journals and 1,5mm thread for the sprocket nut. The right cam is marked with 362 498 and a "S" between the exhaust lobe of cyl 4 and intake lobe of cyl 5. The left cam has the drive for MFI pump. Anyone who knows make and info about these cams?
Try not, Do or Do not
If the cam has 4 cam journals it is probably a set of 906 cams.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
