how to get the exhaust studs of
i want to change my old bad exhaust studs in the cylinder heads,
anyone have some good idea how to get them out, without brake them. (my heads are loose from engine) |
I would start by using multiple applications of a good penetrating oil like PB Blaster over a period of days. Then apply heat from at least a MAP gas torch or small tip acetylene torch around the area of the head where the stud is screwed in and gently try to unscrew the stud. It should go OK but remember - heat is the real trick. Good luck and if they don't come out easily - more heat and patience.
Wer bremst verliert
This question was asked and answered yesterday. 2 threads below this one...Loosening seized nuts etc exhaust system
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
i assume it not a good idea to heat the heads to much? how much heat could they have? for the nuts i use a acetylene torch |
Wer bremst verliert
Sorry if that was too harsh.
Welding nuts to the studs wont hurt the heads, I've had good results with that method countless times.
