cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Parts cleaning
My 2.4 911 E engine is in a zillion pieces in my garage. Parts should be arriving soon and the re-assembly process to begin. I am replacing a piston, all rings, heads rebuilt, chains, ramps etc. Just not splitting the case.
The pics I see of others doing similar rebuilds all look pristine. Mine is nearly as grimy as when I took it apart. For the shade tree mechanic, what is the recommended method, products and tools for cleaning parts both big and small.
Many Thanks!
Chris
73 911 E
Old 09-17-2010, 08:27 AM
E-85 sippin drunk
turbobrat930's Avatar
I would say, bar none, use just plain ole mineral spirits.... take a look at my rebuild post... of cousre, I hand polished mine...but it started by just using mineral spirits.. followed by a wash in dawn detergent and water.... dryed throughly after that... then a light coat of assy lube on the bearing surfaces, etc....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 09-17-2010, 09:50 AM
cmcfaul's Avatar
Where do I get mineral spirits. Advanced Auto?
I have been using copious amounts of Gumout carb cleaner.
Old 09-17-2010, 10:04 AM
E-85 sippin drunk
home depot, lowes, and hardware store.... I live kinda close to a distribution center for an oil company.. I drove over there and brought with me a 5 gallon container.... it was about $2.50 a gallon... very cheap.... it will be close to $10 bucks a gallon at any of the above places..... but you wont use much more than that.. I was filling up my 30 gallon parts cleaning tank, so I bought more....
Old 09-17-2010, 10:09 AM
Porsche Nut
merbesfield's Avatar
turbobrat930, I live in Atlanta and have been paying $6.00 per gallon from the paint store. Where did you find MS for $2.50? I would like to know for the next time I have to drain my parts cleaner.
Old 09-20-2010, 01:08 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Thanks for the MS tip. I wash my car with Dawn (green) its perfect; WARNING it does remove wax.
Back to oil stain part like Heat Exchanger I use this (safe on all metal) see the before and after pics at http://forums.pelicanparts.com/cleaning-detailing-polishing/550748-best-cleaner-bar-none.html
Who Will Live... Will See
Old 09-20-2010, 02:04 AM
haycait911's Avatar
dishwasher as a parts washer - my experiment
Old 09-21-2010, 02:12 PM
SchnellSchweitz's Avatar
Here I am again with my WD-40 (No I do not sell this product).
WD-40 is an amazing cleaner on serious oil build-up. It seems to blend with the existing oil on your parts and allows you to easily rub it off with a simple shop towel. Very little scrubbing compared to the other stuff I tried.
Eric J.
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 09-21-2010, 03:47 PM
