LinkBack Thread Tools Rating: Thread Rating: 15 votes, 4.20 average.
jluetjen's Avatar
How many seconds in a minute?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 02-17-2009, 11:54 AM
Gertvr's Avatar
60 but i think
at 6k RPM you will have 3k power cycles (inlet only open on power cycles) so that should read (6000/2)/60 or 6000/120
Gert
2008 Honda S2000
2003 C4S (Sold)
1975 911 S with some small modifications
"Its good to plan your work, but its even better to do it"
My Gallery
Old 02-17-2009, 12:03 PM
jluetjen's Avatar
I don't think that power cycles matter in this case. We're only interested in one power cycle. If the engine turns over 6000 times in a minute, this is 100 cycles per second. So one rev (aka: 360 degrees) takes .01 seconds. Of this 360 degrees, 270 degrees (270/360 degrees) * .01 seconds would be the time during which the intake valve was open.
John
'69 911E
Old 02-17-2009, 12:48 PM
Gertvr's Avatar
John,
I dug around and found this site. This formula supports your calculation above.
t = (60/n)x(z/360) or t = z/(nx6)
t = time in seconds
n = crankshaft speed in RPM
z = port open duration
This eq to 0.00761s of port open time @ 6K RPM and 274 cam duration.
Gert
2008 Honda S2000
2003 C4S (Sold)
My Gallery
Old 02-17-2009, 05:57 PM
Gertvr's Avatar
Update on Flowbench
I have been working to get the flowbench finished and it is getting close, it took way longer than i thought, but should be able to finish this weekend and start with the calibration.
I also received the silicone and resin for making a mold of the port and CC. I will start getting ready to cast a copy of the head once i cleared up the mess in my garage.
Cheers
Gert
2008 Honda S2000
2003 C4S (Sold)
My Gallery
Old 03-02-2009, 06:43 PM
WOW - WOW
That flowbench is a work of art. Congratulations!
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 03-02-2009, 09:00 PM
911 tweaks's Avatar
...lets hope that after he gets the fine art of flowing & tweaking heads understood that he will give ALL pelicans a great price to flow & tweak our cylinder heads as he ramps up his hobby business... ;-)
Best of luck here Gert!!
A stunning looking cabinet for sure!! How many hrs & how much did all the parts cost to make this flow cabinet??
Bob
I live for 911 tweaks...
Old 03-03-2009, 04:13 AM
jsveb's Avatar
Hi
No matter what that device is capable of doing it definetly does looks awesome.
A display of skill and devotion.
Really looking forward to the actual flow testing.
Jesper
Old 03-03-2009, 09:23 AM
Nicely done, Gert. My compliments to the "Chef".
Now,..........you're gonna learn some things,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-03-2009, 01:57 PM
Gertvr's Avatar
Thanks Steve et al,
I can not wait to start testing i have read so many articles, folmulas, threads and information in books that my head hurts and i have to start doing something with it
Bob
Bob,
I think about $800 in the flowbench including the digital manometer and pitout tubes, and if i have to add it up about 50 hrs labor and about 20 hrs of research.
2008 Honda S2000
2003 C4S (Sold)
My Gallery
Old 03-03-2009, 06:33 PM
Originally Posted by Dynamohum View Post
Talk about a Labor of Love, 2 weeks of Clean up work on my own 3.2 heads
what do you measure with that tool?
Old 03-04-2009, 12:54 AM
Originally Posted by kenikh View Post
John, from what I have seen from the port designs of gurus like Xtreme cylinder heads and Dick Evelrude, they tend concentrate on two things:
Improving turbulence
Making the intake tract a true, tapered venturi
My understanding is that they build velocity by ensuring the entire port is tapered from the port opening to the valve. Every infinitely small increment behind the intake port is an aperture when you cross section a head. Performance is about port design which maximizes velocity as a function of air volume, not a static diameter reading. For example, my 2.3L heads measure at any given diameter on the intake port between 39mm and 40mm. The air flow was modeled to my specific displacement (2.3L, 85mm x 66mm), camshaft (DC44 on 102 lobe centers) and top engine speed (8000 RPM). I provide this example as a counterpoint to the notion of "small" ports: it ain't the ports as much as what is behind them (between the port and the valve).
This what you get when that kind of methodology is applied:
Also notice the ridges from the CNC work - that adds additional turbulence to the mixture.
Then why the ridges in the exhaust port? Does the machinist also want turbulence in the exhaust path? If so, why?
To add to previous posts on turbulence, turbulence is desired only inside the combustion chamber, not in the port where high-velocity gas flow is desired. Correct me if I'm wrong here.
In addition, while cutting off the valve guide flush with the port wall increases flow, fine for a dedicated track engine, the abbreviated valve guide also reduces valve stem stability and thus increases valve guide wear. YMMV.
Sherwood
Old 03-05-2009, 04:27 PM
Hi Sherwood,
A few observations, if I might.
As you know, those are the artifacts of the CNC machining process however I've not seen any noticable effects on the flowbench nor on the engine dyno.
This gets complicated. In the case of the 911 engine's hemispherical chambers, these have little natural swirl of their own and are considered to be pretty lazy (not good). To help fill the chambers and get a proper homogenous fuel/air mix, one employs measures to achieve that in the port's shape, surface finish, and piston crown design. The CNC-machining ridges do assist carbureted engines more than MFI or EFI port-injected ones as they must pass the air/fuel mixture through the entire length of the port. Once again, they have not been a liability on the flowbench or on the dyno,...
This is a very complex subject with a lot of variables.
Sherwood
While that short guide path may suggest a shorter life, we've not seen that to be the case when good non-factory guides are installed and properly fitted to the valve. Like you say, YMMV based on who does what,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-05-2009, 10:00 PM
Hi Steve,
thanks for your astute answers, as always.
I'll have to agree with you in regards to encouraging turbulence in the A/F mixture in the non-squish chamber. However, if the ridges from the cutter promote needed turbulence in the intake port, why then have them in the exhaust ports where turbulence isn't a requirement?
Sherwood
Old 03-06-2009, 12:07 AM
The way I understand it is the ridges in the intake port create a thin boundary layer of air rolling along the surface of the port called surface turbulance, while the air just above the surface of the port is shooting right on through never touching or dragging on the surface of the port.
It's almost as if the air tumbing along the metal surface is like a lubricant for the air moving along quickly just above it because it keeps that air from dragging on the surface of the port.
If the port was perfectly smooth that wouldn't happen and the airflow would drag along instead of tumble right at the surface. The tumbleing surface turbulance also keeps fuel atomized that may wet out on the surface of a smooth port. Especially on carburated and CIS cars.
Rough surfaced intake ports flow a little more air than polished smooth intake ports because of this.
The ridges in the exhaust port will probably fill up with carbon in short time and not have any effect.
Old 03-06-2009, 10:37 AM
Hi Steve,
Sherwood
Hey Sherwood,
The tooling marks are simply the result of the cutter working on the alloy and truly hard to eliminate in the exhaust port without almost doubling the costs. If the machine tool needs to make 4-5 more passes with smaller tooling, its simply adds to the cost and I've not seen a benefit to the additional expense to make it worthwhile doing.
I suppose if those tiny ridges really bothered someone, some time with a mild flapwheel would make them happy,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-06-2009, 04:37 PM
Gertvr's Avatar
Update
Flowbench is now fully done with digital manometer installed and all the velocity probes hooked up. I will wire the garage with the 220v feed and will hopefully be ready to start testing this weekend.
In the mean time i made a mold of the port and CC and will cast a copy of the head to start working with.
There has been some good information from the threads above and what i have taken from that is that the inlet surface finish and port shape is very important to promote good high speed flow, keep fuel in suspension and introduce swirl with the port shape to promote A/F mixture and combustion with the lazy ports. The exhaust port finish is not that important for flow (i.e. doesnot have to be a mirror polish) but could have some benefits if polished i.e. carbon is less likely to stick to port walls and also some heat reflection.
While creating the mold i measured the port volume and it came to 129cc on a centerline lenght of 3.6" This gives an average cross sectional area of 2.18"^.
Some information for interest
Below is the output of the PipeMax program based on my engine configuration and an estimated inlet flow of 236.25 CFM @ 28" as Kenikh had in the thread of the S registry in the beginning of the thread as a target.
These numbers are probably not accurate until it can be corrected to a known or measured engine output but still provides some indications.
From the average CSA above it seems like the port size (CSA) is still ok and should yield ~260Fps @28" (Maybe someone can comment on this)
The VE in this case was calculated based on the total induction flow of 236.25 CFM. (TBC when i have things hooked up to the flowbench)
82.651 Cubic Inches @ 7800 RPM with 126.8 % Volumetric Efficiency PerCent
Required Intake Flow between 234.9 CFM and 248.0 CFM at 28 Inches
Required Exhaust Flow between 184.7 CFM and 199.7 CFM at 28 Inches
------- Piston Motion Data -------
Average Piston Speed (FPM)= 3602.30 in Feet Per Minute
Maximum Piston Speed (FPM)= 5870.11 occurs at 75.584 Degrees ATDC
Piston Depth at 75.584 degree ATDC= 1.2228 inches Cylinder Volume= 220.1 CC
Maximum TDC Rod Tension GForce= 3053.55 G's
Maximum BDC Rod Compression GForce= 1734.86 G's
------- Current Camshaft Specs @ .050 -------
IntOpen= 28.00 IntClose= 60.00 ExhOpen= 49.50 ExhClose= 17.50
Intake Duration @ .050 = 268.00 Exhaust Duration @ .050 = 247.00
Intake CenterLine = 106.00 Exhaust CenterLine = 106.00
Compression Duration= 120.00 Power Duration = 130.50
OverLap Duration = 45.50 Lobe Center Angle (LCA)= 106.00
Camshaft installed Straight Up = 0.00 degrees
-Minimum Intake Valve Lift to prevent Choke = .521 Lift @ 7800 RPM
Minimum Exhaust Valve Lift to prevent Choke = .505 Lift @ 7800 RPM
- Induction System Tuned Lengths - ( Cylinder Head Port + Manifold Runner )
1st Harmonic= 30.867 (usually this Length is never used)
2nd Harmonic= 17.519 (some Sprint Engines and Factory OEM's w/Injectors)
3rd Harmonic= 12.231 (ProStock or Comp SheetMetal Intake)
4th Harmonic= 9.627 (Single-plane Intakes , less Torque)
5th Harmonic= 7.811 (Torque is reduced, even though Tuned Length)
6th Harmonic= 6.571 (Torque is reduced, even though Tuned Length)
7th Harmonic= 5.671 (Torque is greatly reduced, even though Tuned Length)
8th Harmonic= 4.988 (Torque is greatly reduced, even though Tuned Length)
Note> 2nd and 3rd Harmonics typically create the most Peak Torque
4th Harmonic is used to package Induction System underneath Hood
------- Operating RPM Ranges of various Components -------
Camshaft Intake Lobe RPM = 7123 Exhaust Lobe RPM = 5889
Camshaft's Intake and Exhaust Lobes operating RPM range = 4815 to 6815
Note=> Lobe RPMs are only BallPark estimations
Current (Intake Valve Curtain Area -VS- Time) Choke RPM = 7521 RPM
Current (Exhaust Valve Curtain Area -VS- Time) Choke RPM = 7563 RPM
Intake Valve Area + Curtain Area operating RPM Range = 5448 to 7448 RPM
Intake Valve Diameter RPM Range = 5521 to 7521
Intake Flow CFM @28in RPM Range = 6183 to 8183
__________________________________________________ _________________________
Best estimate RPM operating range from all Components = 6051 to 8051
Note=>The BEST Engine Combo will have all Component's RPM Ranges coinciding
--- Cross-Sectional Areas at various Intake Port Velocities (@ 28 in.) ---
182 FPS at Intake Valve Curtain Area= 3.104 sq.in. at .502 Lift
185 FPS at Intake Valve OD Area and at Convergence Lift = .492
229 FPS 90% PerCent Rule Seat-Throat Velocity CSA= 2.464 sq.in. at 7800 RPM
350 FPS Velocity CSA= 1.609 sq.in. at 7800 RPM Port Sonic-Choke with HP Loss
330 FPS Velocity CSA= 1.708 sq.in. at 7800 RPM Port Sonic-Choke with HP Loss
311 FPS Velocity CSA= 1.812 sq.in. at 7800 RPM Smallest Useable Port CSA
300 FPS Velocity CSA= 1.879 sq.in. at 7800 RPM Recommended Smallest Port CSA
285 FPS Velocity CSA= 1.978 sq.in. at 7800 RPM Recommended Smallest Port CSA
260 FPS Velocity CSA= 2.168 sq.in. at 7800 RPM Recommended Port CSA
250 FPS Velocity CSA= 2.255 sq.in. at 7800 RPM Recommended Port CSA
240 FPS Velocity CSA= 2.349 sq.in. at 7800 RPM Largest Intake Port Entry CSA
220 FPS Velocity CSA= 2.562 sq.in. at 7800 RPM Largest Intake Port Entry CSA
210 FPS Velocity CSA= 2.684 sq.in. at 7800 RPM Torque Loss + Reversion
200 FPS Velocity CSA= 2.818 sq.in. at 7800 RPM Torque Loss + Reversion
Cheers
Gert
2008 Honda S2000
2003 C4S (Sold)
My Gallery
Old 03-11-2009, 07:12 AM
jluetjen's Avatar
Gert;
You're making great progress. It looks like you've got a lot of data and calculations there -- the trick will be to sort through it all and pick out what what's important and what doesn't really tell you anything new. A couple of specific questions and comments that came up as I read through your latest post.
I'd beware of using "average cross sectional area" since it's not the average cross section that affects performance so much as the minimum. That being said, port volume is important to know, but I'd measure the volume all the way up the pipe to the butterfly, and then the trumpet tip. Once the air column is in the intake track, it doesn't care if it's in the head, in the throttle or carb body, or in the case of WOT in the trumpet. But I found it interesting comparing the cylinder volume to the intake volume. If you were to dump all of the mixture from the intake into the cylinder, what would happen to the pressure in the intake track?
What cam shaft design are you using?
This sounds about right for a full-race engine.
I don't understand what this set of data tells you. Especially given that everything is at 7800 RPM. BTW, I'd take a look at the model data at your expected torque peak. I believe that this will be key to making the engine strong. Above the engine's peak torque speed, it's just a case of declining returns, and trying to prop-up the curve as long as you can. Below the engine's peak torque engine speed will have a big impact on how driveable an engine is. If you design the engine around "peak HP", that means you're optimizing it's performance within about 500RPM-1000RPM of the engine's rev-limit. In your case this would be 7000-8000 RPM. This is a relatively uncommon situation and you'll risk having the engine be a dog at anything except that very narrow rev range. There are relatively few places on most race track where you'll be pulling those sorts of rev's for any amount of time (Road America and ovals excepted).
John
'69 911E
Old 03-11-2009, 07:47 AM
Gertvr's Avatar
Hi John,
I will be using the DC62 Cams on 106 LCA. They are not full race cams but fairly "hot"
I used the average CSA to get a calculated average flow potential for the whole port and is based on some CFM number chosen, in this case Kenikh's head flow numbers as they are known and can be acheived. This will give a target for the runners and the carb and what i deducted from the program is that they calculate VE % for the whole tract and can use that as a comparitive target when i test it on the flowbench.
The rate of flow will vary at each CSA down the port for the same CFM ( in this case they calculated a value @ 28" simulating peak HP, not sure what they used or how they calculated that and mapped the velocities for a range of CSAs) and in my case the minimum will be (40mm) 1.94 sq in. What i read of the table at the end of the data stream is that at the minimum CSA point I will be @ 278 Fps, the ave CSA puts me @ 260 fps and i am still in the acceptable CSA range before i get into trouble with too big a port.
These are for me at the moment some data points that i can somehow relate to i.e. have known variables like pressure to test at and velocity numbers. I can perform order of magnitude comparisons to at least give me some ideas where i am at.
The formula that we used in the calc above yields a dynamic velocity number (in my case i think it was 285fps) but i don't know at which pressure to do a comparative test to measure that against on the flow bench, so its hard for me to use that as a target, maybe i am missing something and there is a way to do it .
Gert
2008 Honda S2000
2003 C4S (Sold)
My Gallery
Old 03-11-2009, 09:11 AM
304065's Avatar
Gert, great stuff!
To add to John's questions, how can the intake and exhaust lobe rpm be different given that our engines are SOHC, i.e. both lobes are on the same camshaft. Maybe that doesn't make a difference in the calculations.
John, I think the final table shows the port velocity at various port cross sectional areas and the impact on performance at a fixed RPM. Since you cant show a three-variable analysis without a graph, I think that is why RPM is held constant and the velocity varied with area.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-11-2009, 09:22 AM
