Also
Does any body know what intakes will fit an '82 3.0L for the EFI conversion?
3.2 3.3 |
I've seen it done with a 3.2 manifold but he was using the SDS standalone EFI.
http://www.sdsefi.com/ |
The 3.2 manifold fits but it is not a perfect fit. The intake ports on the 3.0 heads are shaped to fit the CIS injectors while the ports on the 3.2 are shaped to fit the electronic injectors. Most people hog out the port on the 3.0 heads to fit the 3.2 manifold. I elected to just swap out to 3.2 heads for a perfect match. Also, I used megasquirt (MS-II) similar to the Tbitz setup.
http://forums.pelicanparts.com/uploa...1235536805.jpg |
The alu 3.2 intake on 3.0 heads leaves a narrow manifold face on one side. Using teh 3.2 insulator blocks helps but it is still narrow.
INJECTORS: $200 FUEL PRESS REGULATOR: $100 WIDE BAND O2 SENSOR: $200 TOTAL COST: $1900 I'd recommend the WBO2 sensor. Although it's not necassary as Tony includes a narrow band sensor w/ the kit. I should be ready to fire it up in about 2 weeks. :D |
| All times are GMT -8. The time now is 11:19 AM. |
