...is my Daughter
3.6 piston install question
Hi All:
I'm getting ready to install OEM pistons in my 3.6 motor. The intake and exhaust pockets that are cast into the piston dome look to be the same diameter. There is an "E" cast in the middle of one of the pockets. Can I assume this is intended to mean EXHAUST side? ![]()
Keep Going! Felmir Singson RGruppe #479 "Living the rest of my life, one minute at a time" |
Manassas, VA
According to the Bentley book, the E goes toward the intake valve. The "1" is the tolerance group (99.970-99.980), the two vertical marks are the weight class, and the "/15" is the manufacturer's mark.
Mark
1991 964 Polar Silver Metallic Turbo Coupe |
...is my Daughter
Mark: Thanks so much for the info! Pistons are now installed!
That's it Felmir, I'm gonna have to give you my cell number so you can quiz me on stuff like that!
![]() Sounds like you're having another productive weekend! Don
Don Weaver-EBS Racing don@ebsracing.com 2006 Cayman S '86 944T '00 Boxster with EBS Racing 3.4 liter engine |
...is my Daughter
Hey Don! I'm putting together a 3.6 for my friend in San Diego. This will be a full rebuild THIS TIME. His wife spun a rod bearing AXing his C4.
Just dyno'd a 2.0S this past weekend.....check it out. 2.0S Video
