Send a message via Yahoo to jjrowe
CAM timing - Sanity Check
I searched and found some had a similar issue but I never saw a resolution.
I am timing the cam on my 1976 911s. I am using modified "SC" cams by camgrinder that should be timed at between 1.4-1.7mm. I set the crank to TDC, set the cam with dot up (and verified that woodruff key is also up). I than adjust intake valve #1. Here is where I run into a question. I have no movement on my dial indicator until AFTER I turn the crank 360.
I have to turn the crank another 20 degrees to move 1.4mm. I set the timing by turning the crank 360 from TDC, stopping, and then moving the cam counterclockwise until I have movement of around 1.55mm. This seemed to work well.
Is it reasonable that I got no movement after 360 degrees from TDC? Wayne's rebuild book indicates that I should see the movement before 360.
Thanks,
Jesse
Old 02-14-2009, 01:47 PM
Manassas, VA
lucittm's Avatar
Jesse,
I went through this also. Not only do you have to be at TDC, but you have to be on the firing cycle of cylinder #1. You can do this by verifying that once you are at TDC, you can also see the distributor fotor is pointing at the #1 plug wire. So you may have to go around twice to get to "firing" at TDC on #1 cylinder, then ensure you have the cam dots up.
1.55mm is good at TDC.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 02-14-2009, 02:17 PM
I am on TDC for cylinder 1. I have lined up the distributor with a mark that was already set. I am just wondering if it is reasonable that my cams are retarded enough that #1 intake doesn't get any lift until beyond TDC for #4. In the rebuild book it states that the lift should happen just before I get to TDC #4 (or 360 from TDC #1)
Jesse
Old 02-14-2009, 04:09 PM
Alright, I think I talked myself through this. Whether I have to move the cam backwards or the crank forward to get the measurement, it doesn't matter. This is only a function of which side my initial setting was off. The only thing that matters is that after I set the cam timing the intake valve on #1 should have opened 1.4-1.7mm when the crank is at TDC for cylinder #4.
Jesse
Old 02-14-2009, 05:57 PM
Warren Hall Student
Bobboloo's Avatar
Jesse
Correct. You have answered your own question.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 02-15-2009, 12:24 PM
