Santa Clarita, Ca.
Question What are these connectors for?
Engine is a 76 2.7. What are these connectors for?
Old 02-22-2009, 07:38 PM
first one is power to blower fan high on top of the #3 runner
2nd pic is connector for vacuum pod sitting under the blower fan in previous pic
controls a vacuum to the warm up regulator on the SC, Ii is called a thermal valve
Bruce
Old 02-23-2009, 08:44 AM
Santa Clarita, Ca.
Thanks Bruce. Here's a pic of the engine. I assume the blower fan sits on the pedestal that's bolted to the intake runners? Also, is the "vacuum pod" missing as well? FYI - this engine is going into a 914/6 conversion so I assume I don't need the blower fan since I won't be using the stock HE's.
Old 02-23-2009, 11:53 AM
In the pic, dropping down off the fan support the thin metal flat is the support for the vacuum pod
914 wont need it
Bruce
Old 02-24-2009, 03:06 PM
