Torque Specs 3.2
I only need one more spec and I promise to buy a new spec book. Could someone give me the Torque specs for the chain sprocket holder bolt on the end of the camshaft. 86 Carrera 3.2. Thanks
Old 03-04-2009, 05:32 PM
MBEngineering's Avatar
HI Sophie
hear you go;
bolt; M12x1.5 120Nm or 87 Ft. Lbs the cam nut is 150Nm.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 03-05-2009, 04:53 AM
Mike I knew yesterday when I posted this that it would be you with the answer again. After this is over and hopefully that will be today I will post some pictures and description for others about this work with the engine in the car. It started as a failed tensioner and 101 Projects . Prject 16. Without it I would have removed the engine . In my case this was better . Given the constraints of a 2 car garage with a 911 engine and transaxle, which gets larger out of the car, this worked out well. Thank you again for your help. As I promised a new spec book is in the works.BORROW A TOOL MORE THAN ONCE. Sophie
Old 03-05-2009, 06:02 AM
