Torque Specs 3.2
I only need one more spec and I promise to buy a new spec book. Could someone give me the Torque specs for the chain sprocket holder bolt on the end of the camshaft. 86 Carrera 3.2. Thanks
HI Sophie
hear you go; bolt; M12x1.5 120Nm or 87 Ft. Lbs the cam nut is 150Nm. regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
Mike I knew yesterday when I posted this that it would be you with the answer again. After this is over and hopefully that will be today I will post some pictures and description for others about this work with the engine in the car. It started as a failed tensioner and 101 Projects . Prject 16. Without it I would have removed the engine . In my case this was better . Given the constraints of a 2 car garage with a 911 engine and transaxle, which gets larger out of the car, this worked out well. Thank you again for your help. As I promised a new spec book is in the works.BORROW A TOOL MORE THAN ONCE. Sophie
