micheloaks's Avatar
fixing leaks
Hi I am relatively new to the 'marvels' of air cooled porsche after 20 years of...alfa lancia and FIAT joy.
I have a 71T with 2,2 motor. It is leaking form the rear seal and also a main seal towards the front of the motor. The case has also had a silasitc applied to it externally by PO.
I want to make it relatively drip free...I stress relative. Can anyone point to a good existing thread or make a simple suggestion re: antidote. At the moment I do not want to totally strip the motor...
cheers Michel
Old 03-05-2009, 02:21 AM
T77911S's Avatar
you can replace the front and rear seals. the motor has to come out but not apart.
it may not help though. there is a rubber O ring on the crank inside the motor, i have seen it wear a groove in the case and replacing seals does no good. i had a 2.2E in my 914-6, i could not get the front seal to stop leaking and my brothers 2.4 was the same way. perhaps someone will chime in to confirm/deny this.
the best thing to do is clean the motor very good and find out for sure where the leaks are coming from.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-05-2009, 04:15 AM
Try not, Do or Do not
Henry Schmidt's Avatar
If the # 8 main bearing is leaking the engine has to come apart. At that point the case must be evaluated and a proper solution applied.
In some cases that means align bore in all bearings including the # 8 which is generally excluded from the align bore process.
Oversized # 8 main bearings are available but very pricey.
Over the past 30 years I have seen all manner of external repair and none have proven to be "worth the effort".
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-05-2009, 08:06 AM
micheloaks's Avatar
thanks any other tips? I keep hearing about a book by 'wayne' who is this? where can it be bought?
Old 03-05-2009, 07:33 PM
Free minder
Aurel's Avatar
Wayne is the owner of this website. You can read the sticky (second thread of the list) for info on his book:
http://www.101projects.com/rebuild.htm
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 03-05-2009, 08:35 PM
micheloaks's Avatar
DOH!!! have 101. Just didn't connect with the name "Wayne" Thanks
Old 03-06-2009, 09:59 PM
