Head Stud Question
After torquing my head down on Cylinder 1 to measure the Deck Height when I went to remove the head one of the Head Studs came off with the Allan head nut on it. I can't seem to remove the Alan head nut, placed it in a vice with a rubber cushion on the stud but it didn't budge.
Can I Just tighten the Stud with the Alan head nut on it to the proper torque when I assemble the Head and Cylinder?
dog
Old 03-07-2009, 05:05 PM
I am no expert, but if no luck after trying penetrant and heat, I would cut the nut off, clean the stud, and reinstall with a new nut.
Maxx
86 Ruf'd and rebuilt (sold)
Old 03-07-2009, 05:13 PM
abit off center
cgarr's Avatar
What year? I hope not a mag case!
______________________
Craig
G2Performance
Old 03-07-2009, 05:48 PM
No, not a MAG case, a 1979 SC case
Old 03-07-2009, 05:55 PM
TibetanT's Avatar
I think if you meet the height specifications for the heads you should be okay. Might want to make sure you did not cross-thread the barrel nut onto the stud.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 03-07-2009, 10:15 PM
You could try to "double nut" the case end of the stud and clamp the nuts in a vise then undo the barrel nut.
If this doesn't work I'd get another stud and barrel nut to replace it. Any engine shop should have an old stud to match whatever you have. I hope you replaced all the lower studs (they are the dreaded old dilivar studs).
-Andy
Old 03-08-2009, 09:36 AM
