Try not, Do or Do not
Henry Schmidt's Avatar
Latest Supertec magic
The engine posted here is a 4 liter normally aspirated project for a SoCal dune buggy .
The engine spec are 76.4 mm stroke and 105 mm bore or 3970cc. The base engine was a 964 3.6. The crank is a GT3 race crank. It has been cross drill for improved rod bearing oiling. The oil pump is also GT3. Case has been shuffle pinned and Supertec head studs were installed. All bearings are Dow dry film moly coated. The pistons and cylinders are custom made for us by Charles @ LN Engineering 11:1 compression ratio www.lnengineering.com . These are really nice pieces. The rods are generation one (127.8mm) GT3 Titanium Pankls. We change the rod bolts to ARP to ensure long life of the engine. The heads were Supertec VentiPort 38/40, twin plug 964 based. Berillium intake seats were added to accomodate the Del West titanium valves and Supertec valve springs and Aasco titanium retainers were fitted. The cams are from John Dougherty DC 40 w 108 lobe center www.drcamshafts.com . The intake system is a modified 3.2 Carrera manifold with a Ford throttle body and operating with a Clewett Engineering / Electromotive engine management www.clewett.com. The flywheel and dual disc clutch package are custom built by Kennedy Engineering to suit the Mendiola sequential MK 6 transmission. www.kennedyeng.com
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-25-2008, 12:02 PM
resident samsquamch
sand_man's Avatar
-jeff
Old 09-25-2008, 12:39 PM
MBruns for President
JeremyD's Avatar
My pants are tight!
Any idea on HP?? Woo woo that is purty
Old 09-25-2008, 12:55 PM
otto in norway's Avatar
Now THAT's an engine!!
Suddenly my engine seems pewny...
Old 09-25-2008, 01:01 PM
911 tweaks's Avatar
no offense to any that contributed to the engineering or build here, but, how long will that "hummer" last before it spins a bearing or breaks a wrist pin or cooks something ? (I hope you say it is a race motor from the dunebuggy reference i.e. live 30 hrs... so I don'tr want to build one and go broke in the process !! :-)
Man that is one wicked, and I mean wicked... attractive set up !!!!!!!!!
Bob
I live for 911 tweaks...
Old 09-25-2008, 01:40 PM
More magic
Note the two different color spots on the crank. These a size designations. The bearings come in three sizes and you match the bearing to the crank via the color code. That's right this engine took two sets of bearings for proper fitment.
The serpentine belt system is also a product of Clewett Engineering.
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2008, 01:53 PM
Eye of the Toiger
matty74's Avatar
Henry,
what type of fan belt is that? where can I get one?
Matt
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 09-25-2008, 02:49 PM
Originally Posted by matty74 View Post
Henry,
Matt
Hi Matt , DR. Porsche here.
Take two aspirins, reread my last post and call me in the morning.
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2008, 03:00 PM
Bob
No offense taken. It's a great question.
The engine is designed to run at relatively low rpm. The first version of the engine made maximum horse power at 6800. It's first life was over 100 hr. The second rebuild lasted about 25 hr. It lost a rod after being run in a inverted position. It seems the customer put his buggy on it's lid.
This engine is designed to make maximum HP at 7200. With these enhanced components and a red line of 7200 I would guess this engine will get a freshen up at 100 hr.
The GT3 engine that shares many of these major components will generally have a service life of 50-75 hr. and that engine spins at 9200+.
The biggest problem we face with this type of application is contamination from sand. It gets in everywhere.
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2008, 03:27 PM
Henry - very nice setup...
Not trying to cause any offence - just have never seen a set of those GT3 rods before, and had a vision in my head of how they "should" look.
Are the Ti Pankl rods always that roughly finished ? Die parting lines, forge flash and grind marks everywhere ? No polish and shot peen ? Nowhere near as pretty as those studs !!
John
Old 09-25-2008, 03:32 PM
(the shotguns)
berettafan's Avatar
tweaks what made you figure that motor would require 'freshening' in terms of hrs vs 100k's of miles?
Henry what makes a motor an 'hours' motor vs. a '200k mile' motor?
Sorry for the dumb questions.
Old 09-25-2008, 04:44 PM
This one is not a dumb question.
Airtime and sand On the street it could very well last 100K+. Like any high performance machine, the harder you drive it , the sorter the life. Ever seen a 50 year old hooker?
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2008, 04:53 PM
John
If you magnify anything enough it tends to look a little rough. But to answer your question, they all look petty much the same. You can't grind on them without replating them so we use them as they come. I'll tell you what, they seem to have a very low failure rate.
And the price is right.
cheers
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2008, 04:59 PM
(the shotguns)
berettafan's Avatar
Ah, airtime meaning wheels in the air then suddenly back on the ground and biting?
Amazing the dunebuggy guys drop this kinda dough!
Old 09-25-2008, 05:00 PM
Thanks for the explaination Henry (and I don't doubt the longevity or failure rates) - can you elaborate on the factory "plating" on the Ti rods ? Is this Tiduran ?
Old 09-25-2008, 05:16 PM
.....edit.......
Years ago there was a So. Cal. guy that put a 900 hp Nissan (NPTI) GTP engine in a sand rail. The buggy was called Mega Bucks and the name fit the project.
Now adays you see buggies with budgets well into the 6 figures. Just the Mendiola transmission will set you back $25K+.
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2008, 05:17 PM
I don't know what it is but I would bet on a product like Casidium. (DLC)
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2008, 05:21 PM
911 tweaks's Avatar
"Ever seen a 50 yr old hooker"............ I am still laughing as I type this!!!!!!!! Henry you kill me !!!!!!!!!!!!!!!!!
Perfect analagey... kinda like "rode (road) hard and put away wet" LOL LOL LOL LOL
Old 09-26-2008, 05:03 AM
Laneco's Avatar
Henry - that is positively drool-worthy...
Without sounding like a complete social clod, roughly what kind of HP/ torque does it throw down? Holy cow 4.0?!!
Or do you just measure this one in pounds of thrust!
angela
Hello
Old 09-26-2008, 06:00 AM
I'm glad to hear that my humor is not lost on everyone. There are some on this forum that take offense to my honest and sometimes edgy approach to communication. Recently an entire thread was removed because a couple of people couldn't see the humor in one or more of my posts. Some posts have even been labeled "unprofessional" by people who believe that professionalism is a allusion to be manipulated not a reflection of performance. I wonder how my customers feel about my sense of humor as it pertains to our performance? This forum is filled will men being men and the ease at which some people take offense is simply astounding.
If you guys keep laughing, I'll keep posting. Hey, you know what, I'll keep posting even if the stodgy curmudgeons don't get it. who knows? I might even throw in a little information backed by 30 years of experience.
Cheers
Henry Schmidt
Ph: 760-728-3062
Old 09-26-2008, 06:13 AM
