Smith
Don't Know what part this is
![]() all I know is that the part on top fits through the part on bottom this would go to a 1980 911 sc |
Navin Johnson
looks like the oil pump pick up...
question is how did it become separated from the oil pump? The pick up tube epoxies into the oil pump.... have seen a few that have been knocked loose...
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Smith
-smith |
Smith
also what do you mean by epoxies to the oil pump?
Navin Johnson
Post a pic of your oil pump if you have a chance?
Smith
oh ok.
sorry, but where is the oil pump exactly? im kind of a rookie |
Smith
The second piece is part of the update screen circa 1980 that the pickup sits into.Replaced the screen filter of the earlier years. The update helped maintain oil pickup in hard corners
Bruce |
Free minder
To access the oil pump, you need to split the case.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
pieces
That is the scavenge pickup for the oil pump, if that fell off while running all the oil ended up in the engine and starved it with nothing in the tank, the scavenge side of the pump's job is to pull the oil that has been thru the engine and put it back in the tank. I have seen those loosen up where they are glued in but the way it fits into the screen kind of holds it from "falling out" when you drop the sump plate and screen its possible to silp it out of the pump if the epoxy is free. did you find metal in the engine, noise, hi oil temp ?
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Smith
so i'm guessing I want to put these back into their proper spot? do I access this spot through the oil sump plate? |
Navin Johnson
Split the case, have the components visually inspected, measured for tolerance.. If the oil pump is still good... you can epoxie the pick up back into the oil pump housing...replace all the worn components... etc...
damage
I would take the engine apart and hopefully it can be rebuilt, putting the pump pickup back in place and starting it just to confirm its hurt bad might not leave you much more than the heads and valve covers, Just be sure to flush and clean the entire oil system, tank,front cooler,lines all of it before the new/repaired engine starts, toss or ultrasonicly clean the engine oil cooler. Best of luck, let us know if you have a question
Mike Bruns
Smith
Navin Johnson
These pieces are not part of any sort of maintenance schedule etc.... Considering some of the other symptoms you mentioned... i.e. noise, and metal in the engine.. I would do a ground up rebuild on the engine...
The last time I saw that pipe on it's own was after it had fallen out, run through the engine and broken a timing chain.
It was very expensive to repair.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
