Duane V's Avatar
Loctite 574 removal
Is there any thing available that will remove 574. I used acetone on the main case surfaces to remove the majority of the sealant but in areas where there has been squeeze out, the build up will not budge. I am a little leery of using a razor blade as I don't want to scratch the surface and have a leak. (the reason the engine came apart in the first place).
Any sugestions?
Duane
79 SC Daily driver. 3.2ss, twin plug
15 Toyota Tundra. Fox 2.5 DSC
Look 695
Ibis Mojo HD
Pivot Vault. Cross/comuter/winter bike
Old 03-06-2009, 08:08 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Methyl Ethyl Ketone (MEK) and a stainless steel tooth brush.
Please be careful with exposure to MEK as it is very toxic.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-06-2009, 09:31 AM
Duane V's Avatar
Thank you Henry
Have a great day
Duane
Look 695
Ibis Mojo HD
Old 03-06-2009, 09:38 AM
juicersr's Avatar
+1. Used it with a mask and gloves outside but still got nauseated. Works pretty good tho.
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 03-06-2009, 10:44 AM
OldTee's Avatar
Aircraft paint remover for the heavy lifting. Lacquer remover for finishing touches.
Old Tee
all 911s sold
Old 03-07-2009, 04:23 PM
mca mca is offline
mca's Avatar
I used a plastic spatula which worked pretty darn well. Also heard that 574 will soften old 574. This was, of course, after I already cleaned up the case.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 03-07-2009, 05:57 PM
Duane V's Avatar
Thanks guys for all the suggestions
The MEK worked great. It's nasty stuff but did a great job.
Hopefully by mid next week the car will together and running leak free.
Duane
Look 695
Ibis Mojo HD
Old 03-09-2009, 05:30 PM
Irrationally exuberant
ChrisBennet's Avatar
I use Permetex Gasket Remover 80646.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-16-2009, 11:53 AM
