kent olsen's Avatar
shipping my crankshaft
I'm shipping my crankshaft out to Calif. Any good ideas for safe shipping?
I'm currently trying to make it fit, stay, in a piece of 5" PVC. I cut two round pieces of wood to screw into the ends so it won't slip out. I'll try to put a rope thru it as well to help UPS handle it.
Any other possibilities?
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 03-13-2009, 01:12 PM
VincentVega's Avatar
The pipe is a good idea. I've built a wooden box out of plywood and some ~2" scrap lumber.
Old 03-13-2009, 02:44 PM
Steve F's Avatar
Be very carefull and "over " build it for protection Follow this thread to see why
Build a crate to ship 915 transmission.
Good Luck,Steve
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 03-13-2009, 02:54 PM
Something to think about, if the energy from a hit or drop transfers through the package the part is in, it can still get damaged. The PVC is a great idea for keeping the bearing surfaces from getting marred but you also need to also absorb the energy if the package gets dropped. You might consider putting the PVC encased crank into a box padded with a spray foam like "great stuff". Spray the foam into trash bags so it doesn't stick to the part or the box. Do half at a time, when the bottom is set do the same thing again for the top. The foam will absorb the shock if the package is dropped. Encasing the foam in bags will make it possible to get to the part without destroying the packing which will be good for the return shipping.
Old 03-13-2009, 05:28 PM
I went to a store that sells packing supplies here in Dallas and bought a GIANT sheet (smallest they sold) of some sort of very dense foam padding which I cut up to ship my cylinder heads to Walt at CE. VERY cheap and the stuff is very strong. You could wrap it around the crank and then slide it in the pvc but it would need to be pretty large diameter pvc.
Good Luck
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 03-13-2009, 06:18 PM
robmog's Avatar
when i sent mine out last week, i rolled it in a long piece of cardboard width about 1" beyond the two ends of the crank. i then secured with cable ties. put it in a box and "stuffed " in more cardboard. it got there safely, and for reasonable cost ($35 to arizona).
i'd be afraid the pvc, being brittle, might crack if dropped. especially where the wood plug screws are near the edge.
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 03-13-2009, 06:44 PM
I ship cranks pretty regularly.
I wrap them first in plastic wrap, then old carpet remnant and then in a heavy duty custom made cardboard box.
No problems to date.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 03-13-2009, 06:48 PM
I wouldn't ship it in anything that can roll easily. If you pack your PVC in a solid crate and pad it well inc. the ends, it should be safe.
regards,
Phil
Old 03-13-2009, 07:41 PM
I used an 8" diameter tube made for pouring concrete footings. Cut to lenght, wrapped the cranked in cardboard and sent it along. Cheap, secure and easy.
Maxx
86 Ruf'd and rebuilt (sold)
Old 03-13-2009, 09:29 PM
one more...
worked @ FEDex for three years in unload ....cranks / heads in cardboard is a BAD idea... the way things get tossed.... lost count of how many Eagle heads / cranks were hanging outta their boxes.
Best bet is buy a Plastic cooler, line with foam board, wrap crank in several plastic bags, more foam board TIGHTLY around crank, any voids put news paper in ( you want everything TIGHT so there is / will be no movement ) , then SCREW and tape top down.....
Dont forget to insure !!!
just my two cents
Norman
Old 03-14-2009, 04:02 PM
I got one shipped to me, seller wrapped it in a big plastic bag, sprayed that expanding foam into a box sized for the crank, inserted the crank and then filled the box with the foam. You could have dropped that thing off a two story building and it would have been fine.
Robert
Currently Porsche less (but the wife has 2)
Old 03-14-2009, 08:12 PM
and so we come full circle
Old 03-15-2009, 09:08 AM
