iamchappy's Avatar
What caused my Supertec Head Stud nuts uneven torque during breakin
After 600 miles driving with cylinder to head oil leaks, i pulled the engine and checked the torque on the head stud nuts @ 30lbs. more than half of them took retorquing, most about 180º some as much as 360º or more.
Copper anti sieze was used.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 03-18-2009, 11:25 AM
Air Medal or two
afterburn 549's Avatar
Ask Henry ?
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 03-18-2009, 11:33 AM
iamchappy's Avatar
I am hoping Henry will chime in. I would like to try and fix this myself, but have promised to let Henry to fix it if i cant. With all the uneven torque it's easy to understand the oily mess.
87 924S
Lexus SC400
Lexus LS400
Old 03-18-2009, 12:05 PM
Air Medal or two
I would make it your ownership to go to him now, rather then start a lot of worthless word chatter here.
He will chime in "if "he sees this..
truly, you need to speak directly to him . That would be the Manly (or womanly) sort of thing to do..not a bunch of gossip
Old 03-18-2009, 12:21 PM
iamchappy's Avatar
I'm not throwing any fault towards the Head Studs which i am certain they are as good as they get, and certainly not Henry who i hold in the highest regard, This is more toward the shop that installed them and rebuilt my engine here in town.
Henry's a very busy guy and i hate to bother him, he will advise me at his convenience not mine.
87 924S
Lexus SC400
Lexus LS400
Old 03-18-2009, 12:28 PM
Air Medal or two
You payed him $$ right ? ??
He and you need to have a conversation.
You both owe ea other that........
Then when that is sorted out...if someone made a mistake maybe we can all learn from it post that.
If it turns out to be M.M scenario (which i doubt) then we would need to be armed.
Remember , Anyone can make a mistake...It is how it is handled that separates the no gooders from the good guys.
Old 03-18-2009, 12:56 PM
iamchappy's Avatar
The shop has taken 2 cracks at it and 3 years i am not going to waste anymore of my time with them and chance it. I have no doubt they would make another attempt at it, i just dont have the confidence or time anymore, they seem too preoccupied with the race cars they service. In all honesty i like the guys over there in the shop, they tried but couldn't sort out the leaks, the engine runs fine just leaks oil, the parts (Cylinders 91 turbo and Heads 79 Sc) may not fit well together this could be the problem. If the anti seize they used was incorrect this may attribute to the nuts not holding the torque, what i've been told these dont need retorquing after break in.
I dont plan on splitting the case the problem lies between the case and the cam towers.
Henry knows of my situation, i have talked to him many times and have purchased most everything that went into my engine from him.
I kick myself over and over for not sending it to Henry from the beginning.
87 924S
Lexus SC400
Lexus LS400
Old 03-18-2009, 01:25 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Call Me!!!!
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-18-2009, 01:32 PM
iamchappy's Avatar
I just got off the phone with Henry, I think we have it all figured out.
A little machine work to the heads should do it.
87 924S
Lexus SC400
Lexus LS400
Old 03-18-2009, 02:21 PM
Air Medal or two
GREAT, Now like I said ..if it is a mistake we all could make ,Please share !!
Old 03-18-2009, 04:27 PM
The engine was assembled using a set of 965 cylinders (91-92 Turbo) and 911 SC heads.
The 965 cylinders are designed to use a .50 mm (.020") steel head gasket unique to the M 30.69 engine.
If the gasket/shim was inadvertently excluded the flange on the cylinder would be in essence .020" shorter than an SC cylinder causing the head the try to seal on the area at the base of the cylinder flange instead of the sealing surface.
This would create an uneven sealing surface and make the heads very unstable.
No proper seal means the heads will move causing the head nuts to come loose and oil to leak from the heads.
This is only a guess and it will have to be disassembled to verify the theory but it sounds like a mismatch with the heads and cylinders.
Henry Schmidt
Ph: 760-728-3062
Old 03-18-2009, 04:54 PM
Air Medal or two
Henry,
If you get the time.........................
Maybe I am in the uninformed camp (as usual)
Could you explain the benefit of using 965 cyl?
What has to be done to get there ?
Where they work and no work?
Etcetera
Old 03-19-2009, 09:24 AM
Henry,
Etcetera
The 965 Turbo cylinders are full finned as opposed to the deleted fin cylinders on a standard 930. Other than the cooling fins and the use of the steel gasket the pistons and cylinders are the same.
To use them as a replacement for a stock 930 set all you need are head gaskets and SC or Carrera cooling tin.
They were used in this application because they were available at a great price.
Henry Schmidt
Ph: 760-728-3062
Old 03-19-2009, 10:23 AM
Air Medal or two
Thanx a bunch !!
Old 03-19-2009, 10:59 AM
Banned
Why the 930 cylinders weren't finned?? stronger perhaps??
Old 03-19-2009, 06:44 PM
The cylinder fins were removed in an attempt to promote a more even cylinder expansion and contraction.
The lower portion of the cylinder was staying hotter than top during cool down and this caused a leak around the heads.
The thought was if the fin were removed from the top of the cylinder that the contraction would be more consistent.
Henry Schmidt
Ph: 760-728-3062
Old 03-20-2009, 10:34 AM
lite75's Avatar
Henry,
Do you feel the half finned cylinders have any cooling issues great enough to exclude them from use on a modified turbo build?
Thanks, Dan
75 930, 76 930, 83 SC EFI turbo
Old 03-20-2009, 09:29 PM
Stranger on the Internet
patkeefe's Avatar
Chappy,
I am glad to see you are sending that engine to Henry; that tub of yours deserves to be done right. You need to be driving that thing! It is the nicest teener on the planet.
Pat
Patrick E. Keefe
78 SC
Old 03-21-2009, 05:54 AM
Originally Posted by lite75 View Post
Henry,
Thanks, Dan
I believe that cylinder head temps are far more worrisome than cylinder temps.
Over the years, I have seen some very reliable, high horse power engines built with factory 97 mm 930 cylinders that performed with little or no problems in reference to cylinder issues.
One race team from the mid 90's ran 3.3 cylinder exclusively in their 600 + hp engines and if memory serves me, they ran at the front and had little or no reliability issues.
That said: you can't have too much cooling on any high performance engine. I have never seen a partial fin cylinder on a factory built race engine.
Henry Schmidt
Ph: 760-728-3062
Old 03-25-2009, 07:09 AM
lite75's Avatar
Thanks for the reply Henry.
Old 03-25-2009, 08:53 AM
