HKZ Bob's Avatar
Experience with AA Perfomance piston set.
Dear all,
I saw this on the web and I would like to know if someone has experience
with the AA Perfomance piston set.
Please let me know your experience.
BR Bob
THIS IS A SET OF BRAND NEW 84MM HIGH COMPRESSION PISTONS AND CYLINDERS. THEY COME COMPLETE WITH ALL CYLINDERS, PISTONS, PISTON RINGS, WRIST PINS AND CIRCLIPS. THESE ARE RARE CORRECT ORIGINAL DOME TOP HIGH COMPRESSION PISTONS THAT ARE PERFECTLY BALANCED AND THE CYLINDERS ARE PERFECTLY HONED AND FINISHED ON THE SUNNEN CNC HONING MACHINE. THESE WILL MAKE YOUR ENGINE A GREAT PERFORMANCE PIECE. BUILD YOUR ENGINE WITH THE CORRECT PARTS AND MAKE BIG HORSEPOWER!
PISTON: 84MM HYPEREUTECTIC PISTON***
COMPRESSION HEIGHT: 34.2mm (1.347")
PISTON DOME TOP: 11mm (.433")HIGH COMPRESSION DOME TOP
ENGINE TYPE: PORSCHE 911
ENGINE SIZE: 2.2L AND 2.4L
CYLINDERS : ALUMINUM CAST IRON SLEEVE
PISTON RINGS: HASTINGS HIGH PERFORMANCE RING SET 1.5mm / 1.5mm OIL: 4mm
MANUFACTURER: AA PERFORMANCE PRODUCTS
Old 04-05-2009, 11:40 AM
HKZ Bob's Avatar
bump
Old 04-16-2009, 08:52 AM
ratpiper71T's Avatar
Hope someone can give you info. I sent them an email request for more info. I'll let you know what they say. It certainly seems like an incredibly economical alternative to the others available.
Mama lock your daughters up that wild bunch is back in town!...And them little girls get frisky when they hear that race-car sound!
Old 04-16-2009, 09:39 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We were given a set to inspect and the results of that inspection were good.
A&A has been in the Porsche after market piston and cylinder business for perhaps 10-12 years. Their main product was an 86 mm 356/912 kit.
Those products have proven themselves over the years to be a top quality replacement.
We see little or no issue in using the A&A products as long as you QC the products before installing them.
We were completely satisfied with the products we received and will probably offer these products for sale in the near future.
It is our policy to test products before we sell them so we built a 73 2.4 using these P&Cs as a test mule.
So far they are performing well and we anticipate that they will offer good service for years to come.
If the choice is used Mahles near the wear limit or the new A&A products, I would opt for the new A&A.
They offer 2 compression ratios for long and short stroke cranks. The high compression pistons on the long crank will theoretically produce over 10:1. These are cast pistons and I believe this application may exceed the limits of any cast piston. This concern is based on years of using 2.2 E pistons on a long stroke crank with less than satisfactory results. If you want high compression I recommend the A&A biral cylinders with JE or equivalent pistons.
In conclusion: The A&A piston and cylinder set is a nice option if budget is a primary concern. In today's economy it generally is.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-16-2009, 11:39 AM
bavaria911's Avatar
Henry,
I want to thank you again for your professional advice.
Looks like my 2.4E sat stored too long (6 yrs) while I was stationed over seas and deployed to Iraq and KFOR.
The shop here in Maryland (AT Speed) did a leakdown/comp test and said the piston rings are possibly rusted and allowing too much compression to pass the test on 3 cylinders. They want to pull the motor, tear down and inspect the heads and P&Cs. Send the heads off for a charge of +/- $1000. The said its about 32 hrs of labor. They'll pull the 46 Webers off (I will sell them...rebuilt with 10 miles on them!) and they'll install the MFI system I have from Germany.
If they say the P&Cs are worn, I guess the AAs with High Comp will work for me?
Your thoughts,
Bavaria911 (Scott)
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 04-17-2009, 09:20 PM
HKZ Bob's Avatar
Hello Scott,
is that you Scott & Betina Kirklighter from Würzburg.
Where have you been. Long time no see.
Greeting from Riedstadt( next to Darmstadt)
Send me an private message.
Greeting Robert
Old 04-17-2009, 11:37 PM
