I've got a c-clamp style valve spring compressor if you're interested. I just PM'd you. Let me know.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Geoff
'82 911SC (Complete rebuild) Click here to go to the project website that chronicles the rebuild process |
Do a leakdown test on #5 to see if the valve is bent. That would influence the decision to tear it down or not.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Geoff
Almost Banned Once
How did this workout? Did you confirm the valve spring seat was missing?
- Peter |
Geoff
Manassas, VA
Geoff,
If you can depress a stock valve spring on an assembled Porsche engine with your hand (no mechanical advantage levers, etc.) ... Remind me to never shake hands with you! The book says that it takes 95 lbs to move the valve off the seat (seat pressure) ! You are The Man. Mark
1991 964 Polar Silver Metallic Turbo Coupe |
Smart quod bastardus
Now the only guy that can move springs with his finger is Chuck Norris according to the lists I have seen on him......joking. Good luck.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
As a further check, rotate the engine to get the #4 valve seated or TDC on number 4 and then press it. If the force to move it 1mm is the same then #5 is no different than than the others and it may be something else.
Just a thought. Also ask the rebuilder what the spring seat pressures and spring heights he set everything to were. This confirms he actually checked and installed them properly. Someone before mentioned 95lbs. don't know if this is right though.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" Last edited by fredmeister; 04-14-2009 at 06:54 AM.. |
Geoff
'82 911SC (Complete rebuild) Click here to go to the project website that chronicles the rebuild process Last edited by squidmarks; 04-14-2009 at 06:10 PM.. |
Ok, so I rec'd the tools and additional valve spring seats/shims from my machinist to allow me to do in-car removal of the springs. I just removed the #5 exhaust valve spring and, as I suspected, there was no spring seat. So, what do I do now?! How do you properly shim a valve spring? I have a handful of shims, but how many do I put on? Do you typically use some sort of load cell to measure spring rate, adjusting with shims as necessary? Or, do you measure the spring height and adjust with shims to some tolerance?
Thanks. Geoff
This is why one should always double check the work of others. That should have been easy to spot before assembly. Good lesson to learn. Sorry it had to be you. Mistakes happen, hope you get it sorted w/o damage to you engine.
2000 VW TDI 224HP/400FT TQ. Pikes Peak World Record Holder 2007 "Fastest Diesel Car" 1973 Porsche 914/6 2.4L Engine rebuild in progress |
The number I have for seat pressure is 75 lbs for a stock SC. There are numbers for the spring height but since you have 5 others to look at you could just measure one of them and match it.
my book has the following numbers for installed height of valve springs for 78-80 SC: intake and exhaust 1.35-1.37 inches (34.2-34.8 mm) -Andy
72 Carrera RS replica, Spec 911 racer |
Carefully install a spring seat, spring retainer and locks, but w/o the spring. Using a vernier caliper, measure the distance between the seat and the bottom of the retainer. That distance is the installed height. Adjust the spring seat thickness to meet specs.
S |
I am using a 964 grind cam on my SC. Since this has a higher valve lift, should the installed spring height be modified? If so, does anyone have these values?
Thanks. Geoff
Valve lift determines how far the retainer moves toward the head. Thus, when setting up valve spring height, there must be adequate clearance so the valve spring doesn't stack (close up completely) nor allow the valve lock to contact the top of the valve guide.
To measure if there's adequate clearance, assemble a valve seat, valve spring and retainer assy. in a a bench vise and compress to the specified installed height. Mount a dial indicator to measure further jaw travel, then compress the assy. the amount of valve lift and see where everything ends up. Are the valve spring coils almost touching. There's a min. suggested clearance. This compressed distance between valve seat and bottom of the retainer should be more than the distance the valve guide projects from the head. You might have to look up the exact numbers somewhere or maybe Steve or Henry or ?? can suggest those values. Something like that. Sherwood |
Geoff
Since you found this error with one valve why not remove the engine and recheck all of them to be sure they are correct? Get the specs on spring seat pressure and installed height and get them all to spec.
You will likely feel better doing it this way as you put another 150k miles on the engine before the next rebuild. Peace of mind is worth alot.
I pulled the engine out of the car and installed the intake valve shimmed to the proper height and, lo and behold, I cannot depress the valve with all my might. So, I removed the intake valve from #4 and found that it, too, did not have a valve spring seat. What I thought was the cad-yellow colored spring seats were actually shims. So, none of my valves have spring seats, it was just that #5 had no shims. Looks like I have my work cut out for me.
Geoff
Wer bremst verliert
...and a refund on the way I hope!
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
