cosmetic refurb 3.2 EFI system
Hi again
Currently working on cosmetically refurbishing the EFI, throttle bodies, intake manifolds etc etc.
Is there any documentation available that will help with reassembly?
Also, what is the recommended treatment for the intake manifolds?
Cheers
Roland
Old 05-04-2009, 06:10 AM
3.4 Bigger is better
88-diamondblue's Avatar
Roland,
Are you doing a intake from a 3.2? I have many pictures of the intake to show how it should go back together. I had the injectors cleaned and also smoothed out the intake runners. There is a company that can force abrasive media through the inside to help even the flow between runners. What I did when I rebuilt the engine.
Before:
After:
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 05-04-2009, 03:47 PM
Hi Michael
That looks great.... What product did you use on the manifolds?
Old 05-05-2009, 03:37 AM
Roland,
I used the super high gloss clear powder coat from Columbiacoatings.com. I ground the casting marks off and bead blasted it. This clear is really tough. I wish I had used this on some of the other parts I powder coated.
Michael
2020 Honda Passport
Old 05-05-2009, 03:18 PM
red901's Avatar
Have you all looked at Caswellplating.com? I used Caswell's powercoating and plating systems to get my level of detail.
Check out photos here:
http://www.early911sregistry.org/forum/showthread.php?t=13138
Tom
Old 05-05-2009, 03:48 PM
Hi Roland,
Can I see a picture from the rear, I want to confirm where to properly connect those vacuum lines.
Thanks,
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 05-07-2009, 01:30 PM
Picture of the rear side
Michael
2020 Honda Passport
Old 05-07-2009, 03:01 PM
