signature65's Avatar
Keep T Cams or Go E
Well Im doing a reseal on my 2.4 T engine and had the heads sent in for a top end job. Since I have everything disassembled I'm thinking cams now. Can I simply switch to E cams from the T cams? It has MFT that is set up for the T engine. I know sending the pump in to change it to E specs is the "right" way to do things but thats another grand that I dont have right now. Thanks.
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 05-17-2009, 09:03 AM
Simply switching cams from T to E will not deliver much benefit.
To really see the difference in the cams, you need the bigger port heads like the 2.2/2.4E. A set of higher CR pistons like the 2.2E would also help realize the full benefit of the cams.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 05-17-2009, 09:14 AM
There might also be an interference issue between T pistons and E cam-controlled valves.
You will confirm of course before proceeding.
Sherwood
Old 05-18-2009, 11:45 AM
