robmog's Avatar
nose bearing replacement
when do you replace it?
routinely?
are there wear limits?
getting to the point of assembling my case and buying the stuff i need.
thanks,
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 05-12-2009, 08:09 AM
abit off center
cgarr's Avatar
There are limits, I don't have them right in front of me but it should be checked and I would keep it well within spec, an out of spec nose bearing will cause the loss of oil pressure to the mains and rods.
______________________
Craig
G2Performance
Old 05-12-2009, 08:24 AM
when you have the engine apart for a rebuild, that's when you replace it, along with the rest of the bearings.
206 637 4071
Old 05-12-2009, 08:37 AM
Fast Corners's Avatar
You can check the nose bearing for wear but I would replace it along with all of the other bearings in the case since you have it cracked open why not refresh everything to the same "new" state? The nose bearing is ~ $100 which I would consider cheap insurance versus having to open the motor again to replace a leaking or worn out one later.
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 05-12-2009, 08:40 AM
robmog's Avatar
i'll replace it.
thanks
bob
1972 E pos
someday....
Old 05-12-2009, 08:41 AM
Rob
I have a fresh unused nose bearing available.
PM me for details.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 05-12-2009, 06:56 PM
