Alusil and Nikasil in one engine, feasible?
Got a set of Alusil p/c and a set of Nikasil p/c, can I pick better ones from both sets and make a good engine?
Of course, the Alusil p/c would not be separated and re-ringed, just transplanted as a whole.
Your opinion or experience would be appreciated!
'87 3.2 Targa
Old 05-14-2009, 07:32 PM
OldTee's Avatar
Great question. Would be interested in the experts answer. Problems I would see would be a slight difference in expansion/contraction characteristics between the cylinders that might put pressure on the studs and cylinder base seals. Otherwise, to resurrect an engine for your own use (not for sale as a rebuilt engine to others) might have merit. This is certainly a short cut and I can't see any professional doing it.
Old Tee
all 911s sold
Old 05-15-2009, 04:37 AM
Maybe one side Alusil and other side Nikasil would work, as there a no thermal problems then.
Piston weigths?
Old 05-15-2009, 05:48 AM
Piston weight is a problem so I was thinking of pairing Alusil p/c, like cyl 1 & 4, or cyl 2 & 5. Alusil uses different rings but I don't know about the piston.
The difference between Alusil and Nikasil may be just inner surface plating, if so there probably would not be much thermal expansion problem if both kinds are put in the same bank.
'87 3.2 Targa
Old 05-15-2009, 06:36 AM
The biggest problem will be balance as the Nikasil and Alusil pistons are very different in weight.
Porsche specs call for a max spread of +/- 4 grams and most piston sets are within +/- 2 grams.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 05-15-2009, 09:51 AM
bls
Old 05-15-2009, 10:19 AM
