Twins are more fun!
JMA-RUF's Avatar
Price check on machining please?
How much does it cost to do the following:
1. Bore 95mm Alusils cylinders to 98mm, and re-coat in Nikasil
2. Machine these cylinders to accept a flame ring
3. Machine a set of heads for the flame rings
4. Twin plug the heads
Thanks in advance...
James
Carrera TT
(3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's)
Old 05-28-2009, 04:13 PM
Try not, Do or Do not
Henry Schmidt's Avatar
1. Bore 95mm Alusils cylinders to 98mm, and re-coat in Nikasil $800-$1000
2. Machine these cylinders to accept a flame ring $280-$450 for both
3. Machine a set of heads for the flame rings[color=red]
4. Twin plug the heads $450-$600
Cheers
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-29-2009, 08:52 AM
Twins are more fun!
JMA-RUF's Avatar
Thanks, Henry. Good to know
James
Carrera TT
Old 05-31-2009, 06:19 PM
