start up mystery help
its for a 2.0T engine ,original 914-6, used waynes book as a guide
everything is new, from top to bottom , took me a while to get it started ( dizzy figuring out session)
its hard to be in the car to turn the key and in the engine bay(especially that one)
here is where the mystery is , it runs , run rough but runs , seems to be running on all 6 but misses , wont run unless i have the hand throttle half up and then its running at about 2500RPM
has webber carbs, i can definitely see fuel being atomised on all 6 TB , the issue is :cylinder 1,,2,3 , when i touch the exhaust its F,,ing hot , on cylinder 4,5,6 , i can keep my hand on it ,,what the ....
what did i do wrong , the points are good , properly gapped, new spark plug, new wire, new rotor and cap,
i just hope its something stupid, i would hate to have to pull it out
thanks in advance
freez
9140431696 painted, with wheels and brake , with all elctrical working , engine in assembly soon to be driven
011850275 911S soft window targa next in the garage
2000 S4 stage 2
660R stroked
Old 06-09-2009, 05:50 PM
Flip the distributor 180 degrees and see if the cold side comes alive. Sounds like you went to lunch when you timed the cams
voice of experience on that one
Bruce
Old 06-09-2009, 06:58 PM
mystery
hi there , i tought thats what it was ,i had eliminated a lot of other things, like spark and fuel, just wishing i made a stupid mistake , it was a stupid mistake just bigger
i however used waynes book as is ,
not sure how to rotate 180 degree, can i just move the plug wire,
i will re-read the book about the cam timing , but any advise will be greatly apreciated
looks like pulling it out is the only option
thanks
Yves
2000 S4 stage 2
660R stroked
Old 06-09-2009, 07:17 PM
mystery solved
ok took me a bit less than an hour to take the engine out, take the cover off and i pulled a .....doh.. the 345 cam is off by 180 degree both on the power stroke at the same time, i had also talked to a friend of mine who is an engine specialist and had never heard of that one , at least nothing is broken ,
dont ask how i did it , but it wont happen again
thanks again, will be doing noise by the week end
Freez
2000 S4 stage 2
660R stroked
Old 06-10-2009, 06:43 PM
