Bead blasting heads
My heads are going for porting and valves guides etc,I have use of a bead blaster.Where is it safe to bead blast the heads ? all over or do I need to stay clear of the cam tower faces and barrel faces ?
www.facebook.com/pages/Bournville-Frameworks |
I'm no expert but I'd definitely stay away from any of the sealing surfaces and obviously the insides.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
abit off center
We bead blast all our heads, (all areas) glass beads have a very low probability of metal removal, in other words it will not change the dimensions.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
bead blast
We bead blast everything as well, just be sure that it is glass beads, and if you have a bit of gasket or some sealer on a machined area remove it instead of trying to blast a stubborn area for a long period.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Forced Induction Junkie
To remove soft pliable material of the head, it's easier to use chemicals. Combustion chamber's carbon build up, it works great.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
cheers guys degrease then in the blast cabinet tomorrow with a very fine bead
Less brakes, more gas!
Just be careful how you move them around in your cabinet... You do not want to put scratches in the surfaces from your cab. grate.
-Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Ok guys I will be careful but while I have your attention
![]() I will be having a valve job and mild port carried out.I have Jenveys which taper from 48mm to 41mm would you open the 39mm inlets to 41mm or leave a step ? BTW I have searched on here and read up on this but still cant decide which way to go
Blend
Mr P,
Blend them through, no question. andy |
Blend them, no question.
Anytime there's a transition step, you stand the strong possibility of fuel dropping out of the mixture and causing uneven fuel mixture distribution, especially at lower RPM's.
