-   -   oil change now broken studs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/485808-oil-change-now-broken-studs.html)
Alan L 08-22-2009 12:04 PM
I am interested how you split the trans from engine. I have always taken them out together.
How did you have enough room to slide the input shaft clear?
I have always had to use special little spacers on the clutch release plate (x3) to allow it to come free of housing (dont quite understand this bit).
Not sure how much trouble you are going to have insewrting engine again.
Are you following a manual?
You can do a leak down now, while on engine stand in shop. This will tell you any problems, and where.
Alan
aadrew10 08-26-2009 11:54 AM
The engine and transmission are held together by 4 bolts. After unbolting them, then lowering the engine(leaving the trans mounted so the whole assembly tilts down) you can simply slide the engine away from the transmission. Take care to support the transmission while doing this so it doesn't fall to the ground and bend the transmission mounts. Removing the rear bumper is also a good idea.
chocolatelab 10-02-2009 07:00 AM
Well
Picking it up today
new studs, valve guides, lap valves, and new rings
They also did some cosmetic stuff
As it stands I am glad I took it to them.
But I will tell you that next time i am doing it myself. Watching them through the whole process took alot of the fear out of it.
If anyone needs help here in socal I would recommend them. PM me if interested their info.
http://forums.pelicanparts.com/uploa...1254494065.jpg
http://forums.pelicanparts.com/uploa...1254494113.jpg
http://forums.pelicanparts.com/uploa...1254494159.jpg
rllevin 10-03-2009 07:14 PM
Do you have hydraulic chain tensioners? Or have you replaced or updated to the most recent mechanical, I believe '81-83? Hate to be asking this after it's all back together.
