SchnellSchweitz's Avatar
Epoxy (?) removed from block.
Hi folks,
I just finished removing what looks like melted epoxy or rubber seals from several locations on my block.
My question is... Do I need to reseal these with anything? Or do I just paint over them. The stuff I removed was a gray color and really strong.
Thanks in advance.
Eric
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 08-10-2009, 08:13 PM
Autobahn Garage
I clean those areas and use J-B weld to replace the factory sealer or epoxy they used.
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 08-10-2009, 08:33 PM
3.4 Bigger is better
88-diamondblue's Avatar
+1 on the JB Weld to seal. That is what I did on mine for the rebuild
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 08-10-2009, 10:46 PM
Those are oil galley plugs and need to be sealed otherwise you will be very sorry,......
JB Weld is OK.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-11-2009, 12:27 AM
Less brakes, more gas!
euro911sc's Avatar
Buy Wayne's book on rebuilding. There is a section in there on all the places you need to remove and replace the factory epoxy. There are additional places, the chain covers come to mind, that need to be checked and/or removed and re-epoxied. Since you have removed it already off the galley plugs, you may consider taking the additional step of removing the plugs and cleaning the galleys out.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 08-11-2009, 05:47 AM
Scuff the area with fine sandpaper so the epoxy sticks real good and use the slow24 hour JB weld.
The quick hardening JB weld doesn't hold up under heat nearly as well or as long and will shrink and delaminate eventually from the heat.
Old 08-11-2009, 10:20 AM
Thanks for the great responses.... I do appreciate your input... Hi Steve!
Old 08-11-2009, 06:50 PM
Does anyone bother to tap and plug those with a pipe plug + locktite
rather than using an interference fit aluminium plug?
andy
Old 08-11-2009, 07:11 PM
B D B D is offline
B D's Avatar
andy
Yes, Henry at Supertec does. Seems to me to be a lot of extra work for no gain, make sure to tap it before cleaning the case.
68 911L
Old 08-12-2009, 08:47 AM
