Try not, Do or Do not
Slides are done, just for fun
Slides are done, What could be cooler
Here are some pictures of the slide valve injection. I have 3 sets. One set is for MFI and the other two can be set up for MFI or EFI. The port size is 43.5 mm as is the slide bore. The over all height is 11.5 " manifold to top of the velocity stack. I also have two sets of stacks that are designed for use with air filters. The slide removal process for cleaning appears to be very simple which will allow for easy maintenance. ![]() ![]() ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 07-23-2009 at 06:24 PM.. |
slides
Those look very nice Henry
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Nice!!!
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
3.4 Bigger is better
Very, Very nice!
I have seen the slides talked about in other posts. What are the advantages?
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
With a slide system....at full throttle....all you have is a great big hole going to the intake.
No restrictions....no butterfly....just a nice smooth hole!! At partial throttle, depending on the leading edge contour of the slide, it can also be very smooth (if the leading edge is not straight, but curved to give an iris effect). And Henry....very nice. Bob
Bob Hutson |
Thanks for all the kind words. I think they're pretty cool too.
Just to be clear. This is not my design. I purchased this project mid stroke and spent the last 1 1/2 trying to finish it up. I was going to try to mass produce them (if 10 qualifies as mass) but it turned out to be way to challenging.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
slide
price?
for such a simple idea i bet there are numerous details that make these difficult to manufacture in small qtys. is there a measureable difference between these and normal butterfly TBs?
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
