Try not, Do or Do not
Henry Schmidt's Avatar
Slides are done, just for fun
Slides are done, What could be cooler
Here are some pictures of the slide valve injection.
I have 3 sets.
One set is for MFI and the other two can be set up for MFI or EFI.
The port size is 43.5 mm as is the slide bore. The over all height is 11.5 " manifold to top of the velocity stack.
I also have two sets of stacks that are designed for use with air filters.
The slide removal process for cleaning appears to be very simple which will allow for easy maintenance.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-23-2009, 03:40 PM
slides
Those look very nice Henry
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 07-23-2009, 05:24 PM
Jeff Alton's Avatar
Nice!!!
www.turn3autosport.com
Old 07-23-2009, 09:39 PM
3.4 Bigger is better
88-diamondblue's Avatar
Very, Very nice!
I have seen the slides talked about in other posts. What are the advantages?
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 07-23-2009, 09:44 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
With a slide system....at full throttle....all you have is a great big hole going to the intake.
No restrictions....no butterfly....just a nice smooth hole!!
At partial throttle, depending on the leading edge contour of the slide, it can also be very smooth (if the leading edge is not straight, but curved to give an iris effect).
And Henry....very nice.
Bob
Bob Hutson
Old 07-24-2009, 06:25 AM
Thanks for all the kind words. I think they're pretty cool too.
Just to be clear. This is not my design. I purchased this project mid stroke and spent the last 1 1/2 trying to finish it up. I was going to try to mass produce them (if 10 qualifies as mass) but it turned out to be way to challenging.
Henry Schmidt
Ph: 760-728-3062
Old 07-24-2009, 08:59 AM
cfc cfc is offline
slide
price?
Old 07-24-2009, 09:09 PM
gestalt1's Avatar
for such a simple idea i bet there are numerous details that make these difficult to manufacture in small qtys. is there a measureable difference between these and normal butterfly TBs?
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 07-25-2009, 06:35 AM
