Tips on cleaning the grease and grime
As I'm checking off the list of tasks to do before I start the car, I have some pretty bad grease and grime underneath the vehicle that I'm sure causes a lot of smoke, or worse, possibly even a fire.
I figure a plastic tarp, simple green and a scraper and a lot of towels. What products do you recommend for cleaning the grease and grime. I'm going to avoid using a brush as I imagine that will spread grease everywhere.
I was also told WD40 can help.
The cleaning will be done in the garage, so I'm trying to contain as much as possible.
Old 09-09-2020, 07:09 AM
Don’t use simple green on aluminum.
Old 09-10-2020, 07:36 PM
Ok, good to know. Thanks for the input. I have an entire gallon of the stuff.
I heard Krud Kutter was good to use, what are your thoughts
Old 09-10-2020, 09:21 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
I use Swish AT30. Gentle and very effective + no toxic fumes. Does not erode or stain aluminum. Used for aircraft & mass transit cleaning.
1986 Targa Guards Red
2021 MT09 SP
Old 09-14-2020, 03:23 PM
I have found a Simple Green product that is actually safe for aluminum but can be hard to find.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 09-16-2020, 09:18 AM
88911coupe - don’t keep us in suspense, what is the Simple Green product?
Thanks,
Old 09-16-2020, 05:40 PM
Racer
winders's Avatar
......14 seconds later:
https://simplegreen.com/industrial/products/extreme-aircraft-precision-cleaner/?locale=en
https://www.amazon.com/Simple-Green-Extreme-Aircraft-Precision/dp/B081D5R6T9
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 09-16-2020, 05:56 PM
I bought some wasn’t impressed and not cheap. I ended up building a wet blaster that makes aluminum look like new.
Old 09-17-2020, 05:34 AM
"When used with caution and according to the instructions, Simple Green All-Purpose Cleaner has been safely and successfully used to clean aluminum. ... Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes."
Or this:
I've used the Simple Green All Purpose on many Aluminum engine parts over the years with no side effect at all. I don't soak it and leave it, I spray it on, scrub if needed, then rinse. Just finished cleaning a Land Rover V8 and all it's parts without any issues. I would not use it on wheels or anything with a nice "coated" surface though.
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 09-18-2020, 08:23 AM
superninety's Avatar
I have used OilEater on all types of metal. It works really well and does not harm anything.
I have had other degreasers attack the metal.
YMMV
Robert Callaway
PCA | Early S Registry | R Gruppe
1970 T Coupe, 1990 C2 Coupe, 2007 Cayman S
1962 S90 Coupe - Gone, but never forgotten...
1985 Targa - A distant memory...
Old 09-20-2020, 03:48 PM
Harpo's Avatar
I use it in my ultrasonic cleaner all the time and I let it soak over night. I'm using about a cup in my 2 gallon tank
Old 09-22-2020, 07:52 AM
Cairo94507's Avatar
Of course please do not use a metal scraper. Plastic please.
'71 914-6 #0372
'17 Macan GTS
Old 09-23-2020, 04:59 AM
