River Rat
Dave 86 930 Fl's Avatar
Good Cams for 930
A buddy of mine is cleaning out his garage of nonessential Porsche parts and he has a set of Web cams that I could pick up. The number on the box is 05-281 and I checked on the Web Cam web site and found the following description:
Valve Lift 485/.452
Duration 258°/246°
Duration @ .050" 238°/226°
Grind Number 20/21
Special performance profile for 911SC / Carrera / 964 engines. Works with stock injection. Price Per Set (2)
I have an 86 turbo with a few bolt-ons: k27-7200, 1 bar boost, B&B exhaust, Andial intercooler, etc. I was thinking about picking them up and using them when a rebuild is necessary.
Does anyone have any experience with these cams in a 930?
Regards, Dave
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 11-11-2008, 07:03 AM
Dave,
Those cams would work just fine in your 930, especially with CIS.
Just make certain that your AFR's are OK above 4K at 1 bar.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-11-2008, 08:34 AM
Call Laurie @ Webcam and ask her opinion relating to how you are going to drive the car. 951-369-5144
She ground them and she knows her stuff.. she's fun to talk to and she can recommend the cam timing for them.
Those cams have a little more lift and duration than 964/C2 cams which for her are grind #40.
Going beyond 964 cams in a CIS 930 with 7:1 compression ratio may leave you wishing you had more midrange power if you drive on the street.
Her favorite 930 street cam is SC/Carrera grind for good midrange power.
Old 11-11-2008, 11:22 AM
Smart quod bastardus
fredmeister's Avatar
Why did not Porsche go with the SC/Carrera grind for good midrange power to begin with when they sold the car?
I don't understand why Porsche never used these cams if they were better than the stock original 930 cams?
Was it emissions or what?
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 11-11-2008, 02:01 PM
They did use them...
They used SC cams in the higher horsepower 930S.
and,
The '94 3.6 liter turbo S came with 964 grind cams in it.
Old 11-11-2008, 02:26 PM
Max Sluiter
Flieger's Avatar
Why don't they put a GT3 motor into a Cayman and strip out the plush interior?
Old 11-11-2008, 03:08 PM
Wer bremst verliert
JohnJL's Avatar
Or a GT2?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-11-2008, 04:54 PM
Made in Flacht
jacksd3's Avatar
I'm guessing that emissions played a big part in cam choice at Porsche in the mid-80s especially for the CA market which took a big chunk of US sales.
1988 944S
2001 Boxster S Seal Grey, M030, PSM
2003 Ford F-350 Dually 6.0 litre Turbo Diesel - You think YOU got torque
1995 International 9200 Road Tractor 11 Litre Single Axle Daycab Eaton Super 10 Tranny
Old 08-06-2009, 01:50 PM
